OK where were we. I was ticking along on this build and then my kid gives me a flu that would rival the black plague. On my back for a couple of weeks but I finally drag my butt out to catch up on real life and finally get back to this build. So when I left off most of the main bits were together and I was smoothing and scribing where needed.
The kit lets you open a couple of panels to reveal some details such as the gun. I figured I put the ladder down but I did not the gun exposed so I decided to close things up, should be easy... Guess again
I guess the hasegawa quality control team was out to lunch when this part of the mould was machined. It is not impossible to fix but you need to correct the bumps and also do some filling as well. I added a plastic card shim and reshaped the bumps out of putty.
Next the nose gave me all kinds of problems pretty much needed a ring of putty to work it out
For this build I am using some black box pallets and bob racks. They cast out of resin and look really good. Unfortunately they did not sit well on the bottom of the fuselage. I found that if I kind of hollowed out the insides I could get them to sit flat.
The engine nozzles were next on the list no real problems, I like the colour that I came up with basically a custom mix of alcads
Now one thing about the nozzles usually these would be something that I would not attach until the model was basically done. The problem is that the kit is designed in such a way that you cannot do that. The problem is that pieces that sidle up beside the nozzles were designed by the same team the made the gun covers. A bit of care and tape is needed to blend this into the fuselage.
After all this is sorted out we can get to paint and preshading
Followed by the initial coat
I also figured that I would use “salt technique†to weather this bird I am trying to get the look while it was deployed
Wish me luck
