NecronautDrummer said:Don't take my word for it, but I think future cut with ammonia will create an airbrush-able acrylic matte finish. Please test it before you try, though!
Would using higher-value resistors on the appropriate LED's dim down your floodlights & nav lights?
Grendels said:I don't think I was clear enough in my post, sorry about that. What I was suggesting is to put a resistor in the wiring harness between the power supply and the landing lights. This will leave your engines with enough voltage to be bright because you are not changing up their voltage, but at the same time you are dimming down the lights you need dim.
Ziz said:Grendels said:I don't think I was clear enough in my post, sorry about that. What I was suggesting is to put a resistor in the wiring harness between the power supply and the landing lights. This will leave your engines with enough voltage to be bright because you are not changing up their voltage, but at the same time you are dimming down the lights you need dim.
I was just going to suggest the same thing - make a Y adapter inside the model at the power jack. One side runs straight 12v, the other has a resistor to cut it down to 9v.
