AKRoast
- Oct 14, 2024
I am still trying to perfect the art of good looking clear canopies. The current build (1/32nd Tamiya Corsair) I did the canopy I thought very carefully and per what I read and saw from multiple sources:
1) I used a clear finish fluid to make it look more real (in my case I don't have any Future but I had bought a small jar of "Looks Like Glass" at my LHS. I had read this is same stuff, essentially, as Future.) I dipped the pieces in the jar and then let dry 48 hours.
2) I masked the outside clear "glass" areas using the kit's pre-drawn masks, and then I turned them over and masked all of interior w/ Tamiya masking tape.
3) I next sprayed the interior frame color on the outside surface and let dry overnight,
4) I then sprayed on two coats of the Tamiya AS-8 exterior color.
So far so good.
Next,
5) After drying a few hours, I removed the masking.
And then it looked bad- the masking tape (both the kit's and from the roll) had left a dull-ing texture on the clear areas. It's like I got fingerprints all over it, but I did not.
I believe it was the Tamiya masking tape interacting with the Clear As Glass stuff. Maybe that stuff never dries hard enough??
Any suggestions for carefully removing this texture without abrading the clear plastic areas or removing or otherwise damaging the Tamiya AS exterior color from the frames? I think I will throw out the expensive "Clear as Glass" stuff, or only brush it on after painting and removing masking.
So far so good.
Next,
