Wow ! This was Read 63 times and no one even attempted to help you ???
I'll give it a try !
My guess would be ! That both of the products you've mentioned are Enamel base or Lacquered base ! Not Acrylics that's for sure !
Meaning they are HOT ! and most likely have somehow "reactivated" the base coat!
Some peoples do it and get no reactions.... That's because they might be doing it in "very" "very" light coats ? or have used an "Acrylic barrier" between the two Enamel base product to prevent such a reaction ? or have let the substrate CURE completely for days if not weeks!!! not everybody builds kits over a week end ! not saying that's you case but if it was a Rush job ??? that could be one of the reasons why you ended up with a Reaction ???
That's my take on it ! if your Model surface is ""ruined"" i.e. bubbles, cracks, discoloration, you name it!!! You might need to strip the paint off and start over ! or a light sanding could save the day !! hard to say without pictures ! I would start fresh ! but that's just me !
and also, if your first coat wasn't dried or cured enough and its not because a surface is Dry to the touch that it is cured !!! You may have trapped some ""Gases"" from the curing process and that may have caused a reaction between the two products ?
We all learn from each other mistakes !
Hope this help a little ???
and I feel sorry, it took so long for someone to answer you post !
Best of luck with your ongoing project !
Norm.
