Jaitea
- Nov 15, 2011
Thanks very much Q & peza
I did a wee bit of work on the 1/144 & brought the mandibles in slightly
I marked out where I'll be cutting:
No serious cutting on the outer surface, just a scalpel slice:
More serious work on the inside, making a trench:
Holding up to the light shows how thin the plastic is being shaved away on the cut line:
Eventually it breaks off with (hopefully) hardly any damage to the surface details:
Both sides of the jaw done & re-attached....the length of the jaw was also shortened:
In comparrison with the un-modded lower Jaw:
Jump forward a couple of nights & I've done the lower jaw also, and used the same technique to cut through the mandibles,......only leaving them still attached at the outermost to allow them to swing in
This is what I mean:
Mandibles
Both hulls done:
Locate both hulls together and I pulled the mandibles closer inwards and taped the tension with electrical tape.
Then I glued the position
Tape removed:
Thanks for looking
John
Mandibles
Both hulls done:
Tape removed:
Thanks for looking
John
