1932 Chrysler Roadster
Junkie
Reaction score
Category: Auto
Name of Build: 1932 Chrysler Roadster
Kit manufacturer: pyro
Scale: 1/32
Description
The build for this one was not so easy as it was a secondhand kit from E bay is are found to the build many parts had been broken or cracked in some way so I had a lot or repair work to do before I glued the parts together.
The main body of the car in green I used an old technique of bathing and polishing is a body had no scratches in it.
For once again this is mostly out the box I had to replace one part as the original part was miss molded I use them fuse wire for the braces of the radiator and as for the white wall tyres I found a new way to do them we and XF2 Tamiya white Matt was straight on and covered well, from start to finish even with the problems it was a very quick build.
Chrysler Imperial Roadster 1 32nd
Final Images
