Finished off with the main color this evening. My priming/base/top layer application still need some fine tuning, as I'm getting the 'orange peel' look in some areas of the model.
I hairsprayed over the base layer, waited 45 mins, then began to apply the acrylic top coat, but it began to dry in a weird 'dried riverbed' type fashion. The next airbrush mix I thinned with lacquer thinner (which I know will make chipping more difficult) but the odd dying pattern disappeared. Perhaps my hairspray brand or application needs some work.
Ian, this thing is looking fantastic. One of the things I've noticed with the chipping fluid/hairspray technique is that I had to do two or three mist coats in order to get rid of that "orange peel" effect. Scott G has, for a lack of a better definition, mastered the chipping technique. He may be able to give you a hand w/ that as well.
that's a good start Ian, i think the lacquer thinner will give the best result for faded looking paint and i cant wait to try it out on my next w/w tank.
I know this is a bit off topic, but what are you using for your photography? Backdrops, lighting and all that. I'm trying to get back to taking better pictures instead of the trusty old iPhone 5.
This piece is looking great too...that color reminds me of my favorite shorts
Nice setup Ian i should try get some of those lights for my setup, your pics are quality with that set up and i actually taught you were using a a big fancy camera,
I look forward to seeing your results on this Ian with the lacquer thinner
The lights were super cheap and the CFL's keep the heat down. My camera has the same size sensor as a lot of big guys, which helps a lot with the image clarity and quality.
