Meng king Tiger + Interior kit
How would you assess the quality of MENG compared to Tamiya?
Both good kits. The more modern the kit, the better the fit.
I often buy old tamiya kit's as they are cheaper but although the fit is usually good, there is alot of flash. Pantherman
Got a bit carried away with the spraying and didn't realise that all these extra parts had to be fitted. At least it's done now, hopefully, maybe, possibly. Pantherman
View attachment 111446View attachment 111447View attachment 111448View attachment 111449View attachment 111450View attachment 111451
Got the gun finished, sprayed and mounted and also managed to finish the ammo for the main build. Going to matt varnish these parts tomorrow to keep them safe from accidents.
Put the parts together to show you what the finished build will look like hopefully. Pantherman
20240106_213128.jpg20240106_213136.jpg20240106_213151.jpg20240106_213203.jpg20240106_213305.jpg
View attachment 111581View attachment 111582View attachment 111583View attachment 111584View attachment 111585
Finally got the lower hull and interior done, primed and base painted. You will have to forgive the hull seem as it's the best fit I could do because I want to lift the whole top section off to be able to see inside.
Working on the turret and track's now so slowly getting there. Pantherman
That's comin together nicely. After the outside is finished I can't imagine that seam will be that noticeable. Plus I don't think there could've been a better location for it. Loving the look of this!
