Thank you fruit ;D
Say, if this is an indication of what your contest diorama will look like - well, then *whistles*, it'll be grand! ;D
Well i hope so anyway.
I glued the walls to the base and left a gap on the one side,this will be where i put the swat team a bit later on,the carpet is really an old blue jumper i cut up to fit and glued into place.
The two outer walls were covered with polyfilla to give an old crumbling/dented wall feel.
The wallpaper inside is simply packaging paper,i chose this paper because it looks untidy and unkept,i have had a look on google and what i see is drug dealers really do not take care of there crack houses.
I will dirty it all up a little later.
I made some stash for the dealers,i cut very small bits of cling film and put filla powder in them to make baggies,well i think that's what they call em.
Also i did the same for the weed,for this i filled the cling film with very fine chive sprinkles.
For some of the furniture i will be using a few toy chairs/table i [
stole borrowed from my nieces toy box :
The settee and two dark orange chairs i made using air drying clay,they don't look perfect because once again it is a unclean dirty place and they would not care for tidiness.
Last i made the bent mishapend door from a cd box,i added thick bolts to the back but you probably wont see them once it's finished.
