urumomo
- Mar 18, 2013
LOL - well I try to .
It can still be confusing .
Excellent idea for repurpose around the house.I'm not sure I understand the issue with the paint being scratched off .
Keep in mind that acrylic needs time beyond being dry to the touch to fully cure into a strong layer .
The polymer chains need to crosslink which takes time - higher temps speed this up .
Think of it like touching Velcro hook & loops together . If you touch them together loosely they stick but the joint is weak .
That is the initial dry to the touch acrylic .
Push them together with more and more pressure -- the increased time / temp -- the joint becomes very strong due to the full entanglement of the hooks and loops . The full crosslinking of the polymer chains .
In short , " green " coatings are weak and easily damaged .
Also , 3 coats of primer shouldn't be necessary .
I know what you mean about trying to avoid wasting paint when mixing in a separate container and then pouring the mix into the AB paint cup .
That's why I use the smallest mixing container I can .
I cut the very bottom off of aspirin or other pill bottles . The bottom 5 mm sometimes .
I use that tiny spoon ( it's for clay sculpting ) to ladle out paint from containers like the AK Real Colors that don't have the dropper top .
It results in less waste , and much easier to clean , over using a pipette since there is far less surface area involved :
I use them for all kinds of paint tasks .
