builder101
- Nov 12, 2012
Happy Holidays to everyone!!
Going to have some time off work and although my genre of models has been sci-fi I have recently had a few car models on the bench. Now, I have dug through the forum and found a lot of tips and advise but was wondering if some car guys could clear up some confusion on getting a nice shiny mirror finish. I have read about paints and usually use MM or Tamiya. But as far as the rubbing compounds, different high grit sand paper, what gloss to use and such I am a little confused. I read in a thread that the paint does not matter much to get a shine that flat paint is fine. Do some of you like to use gloss paint and then clear coat? Do you guys wet sand then gloss? Anyone run me through a little step by step process, I really see some beautiful finishes and would like to try to produce a little better results my self.
After some time I think I am a little better air brushing I have learned to thin the paint better and just put on a real light coat and work my way up with around 18 to 20 PSI and pull back lightly and evenly on my Iwata brush.
I also found that while I thought I was saving a buck or two with using auto primer it does not seem to compare with Tamiya surface primer or even a can of model master primer.
Any tips on a step by step from what clear coat to sanding and polishing methods would be greatly appreciated.
