Jurasikfrank
What a piece of junk...
- Mar 25, 2012
I know no on has been posting in here for a while but still, I thought I'd share a little something. Some of you probably already know about this:
If you have a source 12 volts and planning on lighting 14 LEDs (about 3.3v 20ma each) here's what you can do to reduce the resistance value and draw less current.
EX. 1
In this example, you have 4 times 3 LEDs in series hooked up to 120 ohm resistors and 1 time 2 LEDs hooked up to a 270 ohm resistor. LEDs when connected in series will add up their voltage (3.3v X 3 = 9.9v the 120 ohm resistor dissipates the remaining 3.1v). However, the current will be distributed differently. Each lines of this circuit will see the 12v but the whole circuit will draw only 100 ma (5 lines at about 20ma each).
EX. 2
In this second example, you have 7 times 2 LEDs in series hooked up to 270 ohm resistors. Again, the 7 lines of this circuit will see the 12v but the whole circuit will draw only 140ma (7 lines at about 20ma each).
Here's a link to where I calculate my arrays and where I found these breathtaking images :
http://led.linear1.org
Hope this helps someone.
Remember, less current = less heat... not that we deal with extreme temperatures
Cheers
EX. 1
EX. 2
Cheers
