Hair spray
geegad
Just a quickie
What's the best way to apply hair spray to a model paint brush or airbrush
John
ab just rins out with water quick and easy or you can spray straitht from teh can but the ab gives you more control. TRM just posted how you should use it if u need more or less in his bad nitty topic in the armor section
Cheers Spud will have a look at the armour section also see how your doing with your project
John
Why are you using hair spray? Building a model of Chewie with real hair?
hair spray acts as a barrier so u can take the upper layer off to show wear,
John
with the brand/type of aerosol I used to use (TRESemme Tres Two Ultra Fine Mist) I just sprayed it right from the can and it worked great.
Decanting the pump style hairspray is also very simple to do, simply unscrew the cap and poor into the airbrush color cup.
Now I use the AK stuff though. ;D
;D
lol, umm no.
The Chipping Effects and Worn Effects I used in my Darius miniatures thread.
I know ;D Just yanking your chain ;)...pulling your leg !...winding you up ;D
