so after making sure thy look nice, I fitted them to the bike. Now this was a bit dificult as the batery cabels I had added were getting in the way of fitment, lucky for me I had not completed the running of the cabels as yet, so could still move them around ;D
Then I went onto painting and fitting the raidiator. Just finished the ally paint, still have to do the black in the photo below.
Black finished up as well, and some whethering added.
Then I fiited the single throttle cable that will go to the handel bar. The map call's for just a strait pipe from under the tank ??? ??? so daaft!!
then fiited the air box on the one side, the other side will be left off as I would like to show the work on the carbs.
Fitted the radiator with all it's hosses aswell
Then added the rear sets
and started with a bit of whethering of the frame, still a long way to go.
Then as a last lil bit I started with the body work. went together quite well, but there was still a seam, I had no putty...but remember reading on here somwhere that polistyreen desolved in glue works wonders as a filler....well I can tell you that it does, desolved some in methelyne chloride and applied it. Bit dificult to work with but works wonders in a pinch.
Had a go at sanding it and no worries what so ever. will post some pics of the final sanding as soon as I am done.
Ciao......thanks for whatching.
;D
