RedDragon62
Just trying to build a decent model
- Mar 11, 2013
Are there any tips on using Pledge with Future shine as a gloss? I've tried it once and had some horrible results.
Elm City Hobbies said:I assume you are using it in an airbrush?
Multiple light coats, about 20psi.
Last time I glossed a car with it I think I did 4-5 coats before I was finished. If you end up getting a run, sit it on a piece of paper towel, and the run will wick off, and self leveling properties will smooth it out, you can then go back once it is dry and put more coats on as needed.
