Question about sealing before molding
Spockr
I've made a part that is comprised of wood, metal and aves apoxy sculpt. I plan to make a mold of it with either Amazing Mold Putty or Smooth-on Mold-Star-15. I've sanded the wood part smooth but am concerned that the grain will imprint into the mold. This would be bad since the part is supposed to represent a smooth metallic surface. To prevent the wood grain from showing it seems like I'll need to apply something to seal the part and keep it smooth.
What material should I use to seal this part? Primer? Gesso? Other suggestions?
Also, how long should I let the sealed part cure before making the mold?
Thanks,
Matt
Primer, paint etc. should work just fine. A friend of mine who casts resin often primes the master depending on what it is for just this very reason.
HTH
to be extra sure you could cover the wood parts with bondo and sand them smooth then primer. I've seen people do this with balsa wood and their molds came out perfect.
