the Baron
- May 12, 2009
'Ev'ning, everybody!
Well, here it is, right at the deadline, my completed Hellcat:
I almost gave up on finishing at all, when I had problems touching up the paint where the tape had pulled it up. I had some overspray, D'OH! I went back and forth, masking, touching up, then masking again, until I decided I'd had enough. So, there are still patches where you can see some overspray, but I can live with it.
The national insignia are from Bare Metal Foil, and they went on without problem, except for the one on the underside of the starboard wing, which split into three pieces. But I was able to line them up and then let them alone. The BMF decals settled down nicely, and I used no setting solution.
I decided to use the kit sheet for the aircraft number, however, and I probably should have found some other numbers. The sheet was damaged, and if you see silvering, it's not under the decal, it's the surface, the carrier film turned a little milky in places. Also, they're pretty thin. But with the weathering, they don't look too bad.
Weathering was carried out with chalk pastels, for the exhaust staining, and the blast staining for the 6 .50's; with acrylic washes for the oil and fuel staining; and with a kind of filter of white acrylic, to fade the blue upper surfaces. I used about 2 oz of water and 1 drop of white acrylic (99-cent Michael's on-sale white acrylic), and used a broad brush to apply it, in several layers.
On the white undersides, I used acrylic burnt siena for the washes, because it would stand out so well against the white. And my modified tires turned out pretty nicely, with a coat of paint (NATO Black is my color now for rubber in scale).
The masking came of the canopy relatively easily, though there was some adhesive left behind. I tried diluted Windex, and then broke out the WD-40, which worked better. If you look closely, you can see some paint flaking off the canopy frame, but, don't look closely Oh, and I used white glue to fill the worst of the gaps between the canopy and the fuselage. I used a toothpick to apply it into the gaps, and I dipped my fingertip in water and used that to smooth it out. It worked out pretty well.
The markings aren't based on any specific aircraft, but just represent an F6F-3 at the end of the summer, 1943.
I enjoyed building this kit, and accomplished what I wanted to do--to backdate the Monogram kit to be a -3, to add cockpit details, and to do the two-tone blue over white camoflage. I had to give up on retaining all of the operating features, but that's not really a negative. It was another fun trip down memory lane, but I am ready to pick up the Eduard Hellcat and give that a whirl
Thanks for looking, as always, comments and criticisms are welcome!
YbiC
Brad
YbiC
Brad
