Help with sidewalls
Omegaman55
Hello Falcon friends!
I am building my MPC Falcon in the Sci-Fi section http://www.scalemodeladdict.com/forum/index.php/topic,4654.0.html
Please do drop in and let me know what you think and pointers are always welcome.
Anyway, getting to the point! I am fitting the Sidewall kit from Bluemoon and need to know how far to trim them height wise???
I did read on another forum they are 14mm round the mandibles and 16mm round the saucer section???? Any thoughts and comments would be more than welcome.
Omegaman55
Omegaman55 has had a post on his thread by Ozzy with his overall dimensions to modify the MPC Falcon:
Hi Oamegaman55,
I only just saw your post regarding the side walls height etc. So if you dont mind I have cut and past something I posted on SSM forum regarding the same thing. You mentioned 14mm and 16mm for the side walls which I think would have come from John Martins build at SSM. When speeking to John about my first build we found John had mis-quoted the side walls height in his blog. His were 15mm not 14. He has no idea why he put 14mm.
Anyway, If you have not already made adjustment to the walls here are my measurements and adjustments to the AMT Falcon against the 5 foot falcon. I have never made comparisments against the 32inch falcon so I dont know if it is a good reference when converting AMT to represent the 32 inch.
Mandible walls 15mm
Secondary circile Walls 15mm or 15.5
Engine grill 16mm
Overhang secondary circile 4.4mm
Overhang engine grill 8.75mm
Viewable area after overhang
Mandible walls 1.5mm
Seconday circile walls 13.5mm
Engine grill 11.5mm
For those wanting to correct the dish
Scanner dish 43.97mm
Side cones/escape pods
inner dia 38.69mm
outer dia 43.97mm
overhang 4.mm
Docking arms
Lenght 100.26m
Width top 28.14mm
width of sides walls/inner 47.49
width of side walls/ outer 33.42
Corrections to Cockpit tube and canopy
John Martins templates represent this very well.
Walkway
Diameter 43.79mm
Length/short part 99mm
Length/long part 121mm
Cockpit tube section
Diameter 43.79mm
Length long side 51.0mm
Lenght short side 24.62
Canopy
length 28.14
Diam rear 43.79mm
Windows
Centre window diam/inner 14.8mm
Center window diam/outer 18.8mm
Front split windows dia/inner 18.8mm
Four split windows dia/outer 30.5mm
Outer rim of front windows/diam 31.8mm
Here is a pic of when I built my new walls.
http://i80.photobucket.com/albums/j200/guancheisland/Millennium%20Falcon/IMG_0236.jpg
And a pic of the actual 5' falcon wall. It looks correct width
http://i80.photobucket.com/albums/j200/guancheisland/Millennium%20Falcon/P1010058.jpg
And the other side compared
http://i80.photobucket.com/albums/j200/guancheisland/Millennium%20Falcon/IMG_0549.jpg
http://i80.photobucket.com/albums/j200/guancheisland/Millennium%20Falcon/12220234.jpg
PS: your falcon is looking good so far.
Ozzy
J
