ExodusInside
- Feb 21, 2012
Evenin folks. Back with another build. This time I'll be putting together the Astray Red Frame MS from Gundam SEED Destiny. Here's some backstory on it.
The MBF-P02 Astray Red Frame is a prototype combat mobile suit developed using stolen data from the Earth Alliance's G Project. Most of the technology from the G Project was successfully copied with the exception of Phase Shift armor. In its place the Astrays' designers made the machines out of a lighter foaming metal compound and were built with minimal armor over the frame. This made the Astray mobile suits lighter and faster than their G Project counterparts.
Originally, the Astray Red Frame was armed with the standard armament of the other prototype Astray suits. These weapons include two head-mounted "Igelstellung" 75mm multi-barrel CIWS, two back-mounted beam sabers for close combat, a Type 71 beam rifle and a single physical shield. Red Frame pilot Lowe Guele eventually added another piece of armament to the Red Frame standard armament, which is the "Gerbera Straight" katana. Lowe also created a 150 meters long version of this sword, which however can't be carried by the Red Frame in its normal configuration.
When equipped with the "Mars Jacket" armor, additional armament is added to the suit. These additional weapons include two katanas, two high-energy beam cannons, a single high-energy beam cannon and a dual beam naginata.
Unlike the other Astray units, the Red Frame had an additional feature, which could be used as a weapon. Like other mobile suits that use beam weapons, the Red Frame is equipped with hand plugs to exchange energy with weapons the suit carries. The Red Frame has the ability to emit beam weapon-like energy from his hand plugs which could be used as a emergency weapon, for example to temporarily blind enemies.
On to the box art!
On to the box art!
