liquorboxracing
- Oct 12, 2012
I have several small projects going and this is one of them. I am building a Replica of the P-47 Razorback that is in the National Museum of the United States Air Force. It is painted after the plane Col. Neel Kearby flew know as the Fiery Ginger IV.
I started with the 1/72 Academy kit. Mostly going to be right out of the box. I have already built the Cockpit and detail painted, as well as joined the two halves of the fusalage together. I smoothed the seems then glued both the wing sections together. I cut the guns from the wings, and drilled the wings for hypodermic tubing. I glued the wings to fusalage, and began sanding the mating surfaces even to one another. I then cut and glued the hypodermic tubing in the wings.
I found decals for this build from CanMilAir and have them already. They look great and match the colors that are on the plane in the museum. I need to order the correct wheels for this build though. More to come.
