Airbrush problems
Runway
My airbrush was good and clean but when i did my priming. I am seeing little blotches. And what to be little hairs. Useing Valero primer. But it did not say to thin. Should i be thining all primers even when they say not necessary?
so we're not going to check ?
What kind of primer is it ? Acrylic or polyurethane ?
Wnen i test my flow rate on a peace of work i don't see any of that. That showed up on tne model.
What tip size and air pressure and how far are you from the work ?
It's OK to thin any coating for AB work since environments differ . Just use the smallest amount necessary .
Can you post a pic of the problem ?
I'm confused why you're not having the issue on your test piece .
