DreamKnight
- Dec 8, 2009
OK, so I really start to dive in tonite to use Vallejo Model Paints..
Let me give you a little background. I bought 5 bottles from ECH about a couple of weeks ago. When they came, they were in my mailbox. Now... I live in L.A. When I say it's cold here, that usually means it's 68f degrees... ok? The day the paints came, it was pretty hot in L.A. and sitting in my metal mailbox down the street, it was pretty much an oven. When I was carrying the box back to my place, I had to switch the box to my other hand back and forth.
Well, Of course I run up to my second floor and rip open the package and open a bottle. I think it was the intermediate blue. It basically kinda gushed out a few drops. Cleaned it up, put a few drops in my cup and thinned it with regular water and sprayed and designed a neat card box box. Sprayed it on some plastic too to see how it felt when dry. Love the feel.
It's kinda like toothpaste right now. I have a bunch of bottles coming in tomorrow so I can compare.
Anyways... I put some in my airbrush tonite. This IS NOT TAMIYA. lol No where near, no sir, no how. This definitely is going to take a getting used to. I've used up almost half of the thinner bottle trying to figure it out.
When I first started to spray, it came out perfect... then SPLAT. Big out gusher of watery paint and then going find again...and then clogged. So I cleaned out the brush and started again. Went through it like about 3 or 4 tries then gave up for the night (kinda tired anyways so I'm not at my best) and I'll try tomorrow. So I did some research and come here to post some questions.
My corsair is kinda a mess right now but nothing I can't fix. I've gotten out of bigger blotched jobs.
1. It's it suppose to be as thick as paste? It wasn't like this when I first got them but then I think they were just finished boiling in the mailbox.
2. Where I messed up I let it dry to the touch and tried to sand it. Is it THIS soft? Or it just hasn't cured? Because it doesn't seem this soft in areas when the paint it thinly painted on. The paint just lifted off the plastic like dried PVA glue. I stopped the sanding once I got the major gunk off. I'm hoping it'll harden by tomorrow so I can sand down the edges between paint and no paint flush to the plastic. Right now it look like huge area got paint chipped. Kinda cool effect though. I might have to try that later on terrain or something. (See pic)
3. Continuing with the last question, with Tamiya I can use regular paint as a base/primer. I've done it this way for a while now. With the way the paint just lifted off the plastic, is it because I didn't let it cure or you NEED to have a real primer to put on Vallejo?
4. I'm going through thinner really quick here. Even if I didn't mess up, this little bottle wouldn't last long. Does the distill water mix with retardant and a couple drops of future work just as good?
I should have read more up on it but I doubt I'd know to ask these questions unless I didn't try it first. lol
Thanks!
[attachment deleted by admin]
Thanks!
