JS 3 Berlin 1945 FINISHED
danb
M.A.F.V.A British National Champion 2013
Here is my kit i will be using for the BSC the base for this will be Tamiyas excellently moulded kit a metal barrel a small helping of PE and some fruils general idea for this will be a what if situation if the war had carried on into the later stages of 1945 and the russian had brought this to the battle table ;) hopefully you all like my choice
Dan B
Re: JS 3 Berlin 1945
Thanks for all the comments made a start on the running gear last night im hoping to have a progress update in the next few days :)
Dan B
Should be fun. Will you have to add a piece to the house once completed? ;D
Ooo I love the look of Russian tanks. There's something about the lines that inspire sci-fi.
Heres a small update progress is slow as there has been a lot of preparation to do before i can start putting the kit together the molded fenders were sawn off then i had to add the angled hull armour which the fenders covered i used plasticard sheet for this then filler was added to hide any gaps weld beads added with Magiscuplt textured with Tamiya Putty mixed with glue then i made a start on all the torch cut edges using a a sharp blade then use glue to smooth over i have decided to loose 2 road wheels on the right side so i have lowered the suspension by 50% to get it to lean a little ;) more soon
Dan B
Like all the extra work you putting into this mate, it'll really show through at the end.
Thanks for the comments the kits texture is very good the best i have seen on any model i have added a small amount to differ the panels managed to get tracks and the barrel at Sundays show but still got to purchase some PE to start the turret :)
Dan B
Looking good so far. One has to love the early IS-line of tanks... :D
Perhaps a stupid question, but I'm not entirely sure why you cut into the front and the fenders? Was the kit not accurate or...?
So are you moving onto this now that the truck is done!??? ;D
Yes mate i have been working on it all week i have a few details to add then i will post up the build progress i have enjoyed every second of this build 1 of Tamiyas best kits IMHO cant fault it 1 bit ;)
Dan B
As promised here is the long awaited update :-[ the scene is set Berlin 1946 the Soviets release a beast into the unruly streets due to the close combat any piece of sheet metal is used to up armour there tanks well thats the idea anyways 8) lol i have used parts from the spares box to add a bit of detail side armour was made from scrap pieces of PE fret and styrene hopeyou chaps like the progress still have some areas to attend to then it will be prime time ;)
Dan B
oh my, mate I defo like that look. This one will be very cool when weathered no doubt!!!!
Cheers
0 Words
