Gloss coat between steps not working?
49thStateRT
Silver Member
Hi
Background: I have two models now where I used an Ammo acrylic primer, then a mix of AB Tamiya acrylics and hand painted details that are often done with Testors Enamel because I like the feel and coverage of it with a brush vs Tamiya acrylics with one. After that I AB on Vallejo acrylic gloss coat, apply decals, and AB on another gloss coat. The gloss coats seem pretty thick. I let dry a day between. I then use Tamiya oil based panel line/pin wash with their little built in brush.
Ok now the issue:
when I go back to wipe off excess wash, the wash has gotten thru the gloss coat and softened the enamel paint. If I then rub that detail, it smudges/roughens the enamel.
I had seen on YT that the gloss coat had to be acrylic so an oil based wash would not do that? And it had to be an oil based wash because the gloss coat and paint coats were mostly acrylics. Maybe I can't use any enamel paint for details in this scenario? Or maybe the Vallejo gloss coat is too weak? Maybe not enough drying time between steps?
Any opinions would be appreciated. Thanks
I'm no expert of the various paint types, in fact I'm below average. Still trying to get over what I learned in the 1970s that acrylic were water based, enamels used turpentine and lacquer user lacquer thinner. Whether that was true back then or not, it is not even close to true in this new age.
I spent MONTHS trying to figure out how to put a clear coat down to enable enamel or oil washes. Ruined one kit trying (https://www.scalemodeladdict.com/threads/f-16-aggressor.15628/) and came out with poor results on several. But I figured it out!
I usually used Tamiya acrylics for the color coat, used AK clears, and enamel/oil washes. When that didn't work I tried Model Masters enamels as the base coat and tried various clears, Tamiya acrylic, Tamiya Lacquer, even some Testors clears. I tried different solvents (turpentine, white spirits, artist oils, you name it) for the washes and filters. No matter what various product I used my weathering/shading/panel-lining would eat the clear and attack the base color.
Turns out the entire time it was me. I was putting the clear down WAAAY too thin. This did occur to me early on, I tried four coats of clear one time thinking maybe it was too thin, four coats would do it right? Well, one coat is enough if you spray it thick and heavy enough.
I learned to use an airbrush as a watercolor technique, hyper thin spray that allows the white paper to show through. On my models I would make multiple passed with slight color variations between each, getting full coverage and opacity by building up the layers. This is (in my opinion) a good way to paint in color, but it is trash for clear coating.
I solved it by getting a cheap brush with 0.50 and spraying the clear so thick I swear it was gonna run or get orange peel, but it didn't. I thought I was going to plug up recessed rivets and panel lines too, but it didn't. I cannot say for certain this is your problem, but damn is it worth a try!
I'm getting great results with X-22 as my gloss coat. I can scrub and rub hard on top of it with a turpentine soaked brush with no ill effects. Grab your mule, paint it heavy and wait 48 hours and let me know if that helps.
Thank you - I think a) will try Tamiya x-22 as gloss rather than truly water based Vallejo, b) try even thicker 2-coats of clear, and c) add 24 hours curing to every step. I figured out finally to have 2 builds going at once to allow staying busy between coats (well busy with my hobby instead of working more or doing home improvement lol). So far washes on general have not looked nearly as nice or effective as in the videos. I also need to try the build up of color variation in paint layers. I did get a cheap master airbrush trigger model that might as well be a garden hose sprayer, for my primer and clear coats. I have been using Mr.hobby aqueous matte coat rattle can for final step. Doesn't matte it quite well enough in my opinion.
Here is finished product
I generally like the Vallejo product line, but their gloss clear is the worst clear coat I've ever tried. Their semi-gloss and flat clears are fine, but the gloss is a mess waiting to happen. Go figure.
In general, clear coats are a bear, and an unfriendly one at that, because it is hard to see how heavy a coating one is applying. Working with a light source at an angle to the surface, one can sometimes judge by the surface glare how thick the coating is.
Now the real joker: Just because an acrylic coating is water based does not mean it will not be attacked by other solvents. When in doubt, test this on scrap, not the model you've been working on for a month.
Also, gloss paints in general cure more slowly than flat paints, so give them more time to cure.
I second using a wash made from water and water-soluable acrylics, over any commerically-made washes made from other media, like enamels or oils and mineral spirits, or any kind of lacquers. And remember that "acrylic" does not mean "water-soluable". Many brands of acrylics are water-based, eg, Andrea, Vallejo, but there are others that aren't. We've got a number of discussions here in the forum to explain the chemistry, which are good for reference.
I like to use water-based craft store brands and plain ol' water to make washes, generally.
Best regards,
Brad
In the heat of the creative moment, or the impatience to finish, it is so easy to forget.
Maybe it's the habit of my professional lifetime: test first, build later. Or maybe it's the frustration factor. For so many years my building time was very limited, and making a materials mistake on a build just added to the frustration. So I took a few minutes to test combinations of coatings on paint hulks and scrap. Building is supposed to be fun, not frustration. That investment of a small amount of precious modeling time saved ENORMOUS amounts of frustration.
We all have to hurry a lot in this society. In scale modeling, if you are in a hurry, it is not a hobby, it's a hassle.
{snip}
Best regards,
Brad
You might try adding a small bit of Calgon™ or distilled white vinegar (a drop or two) to the wash to reduce the water's surface tension. Some of these craft paints already have an aditive that does the same thing, but it varies.
Dish soap also works as a surface tension reducer, and some detergents, too. I tend to use Woolite™, and Ivory™.
Which, it bears repeating, makes it completely unnecessary to apply clear coats at all — except if you want/need them to make the decals adhere better, of course. But you don't need one to protect the paintwork underneath from an aggressive wash.
However, there is one "risk" in water-based washes, in that they're more likely to form tide lines at the bottoms of inclined or vertical panels. You will need to keep wicking away the paint that builds up there while the wash dries, and may have to drybrush over it with the colour underneath the wash to get rid of it completely after it has thoroughly dried.
One other argument for using clear coats (other than decals) it that some washes flow into panel lines better with the clear coat. I think that depends a great deal on the base coat, Tamiya XF acrylics are terrible for this in my opinion. Tamiya's own product (enamel panel liner) will not flow well at all on top of XF paint.
I have tried using an acrylic wash on top of enamel color, but I did not use any detergent or anything to lower the surface tension, so it had a tendency to "puddle". I think I'll give some of the tips above a try.
...However, there is one "risk" in water-based washes, in that they're more likely to form tide lines at the bottoms of inclined or vertical panels...
The tip others have mentioned of adding a drop of dishwashing liquid to the wash can help with that, too, I've found.
Drifting off topic a little, but with a drop of dishwashing liquid, a drop of water, and some ground pastel chalks, and I can make a sludge for weathering. It looks like mud stuck or caked on the sprockets and bogeys of a tank, for example. I have used an old paintbrush to apply it, as well as coffee stirring sticks and toothpicks.
Jakko nailed it again, HA! Spot on, Mate. ;)
However, I do from time to time use the old tried, tested, and true Testers Gloss Coat in a rattle can. I let it dry overnight, then wash with oils, never enamels, (my enamels rarely, if ever, get used anymore). I've never had an issue with anything giving me grief. I tend to lean towards your drying time, and more than likely the use of enamels, because I've honestly never had the issue you are describing.
Most of the old salts do use oils for pin washes, etc. You can get a decent set from Mig, Ammo, etc., but I personally would not use enamels for any washes whatsoever. Hope that helps, AK.
Cheers, Ski.
I bought two big rattle cans of Rustoleum matte and gloss clear enamels to use instead of Vallejo gloss acrylic air brushed on and Mr. Super smooth clear matte from a rattle can. I will see if it is same, better or worse as the intermediate and final coats.
I am starting to question why we pay $6 for 10mil of Tamiya acrylic paint or 0.25oz of testors enamel vs just buying and mixing colors withhigh quality craft store acrylic paints for maybe 1/3 the price or less per unit. But I also don't want to buy the wrong paint at a craft store and screw up a model, and it is nice to know you are getting exactly Italian Red with the Tamiya brand for example.
You can use that kind of paint — if I'm not mistaken, @Grumpa does all the time, for example. However, are you sure you'll be saving if you do? Sure, they're cheaper in money, but are they also cheaper in time if you have to keep mixing the colours you need? Or if you have to go over something four times instead of once or twice to get them to cover? Or if they clog your airbrush because they have much coarser pigment than modelling paints do?
Tamiya paint is noticeably cheaper if you buy it in 23 ml bottles, BTW. Paints you know you use a lot, you probably don't want to be buying in 10 ml at a time.
Jakko makes several excellent points about the use of modeling specific paint and paints made for other purposes. Sure, the price per gallon of modeling paints seems outrageous. In my retired professional opinion, it is at least faintly outrageous—but there is considerable justification for the price. The first, and from the builder's standpoint the most important, is color accuracy.
Color matching paint is a mixture of art and science. It used to be all art, but computers and technology have made it more science and less art, nevertheless the art is still there. Color matching, called shading in the paint industry, using only the human eye, is an art. When did you last have your color vision checked? It varies from person to person, and changes with age. If you have a cold or flu, it also changes temporarily. The human eye is a wondrous thing, but human perception is easily fooled.
The paint technician has access to a very wide selection of very precisely made pigments. Small amount of these have a significant effect on the shade of a color. To get the same effect by mixing paints is very inefficient and likely to be quite wasteful. Can it be done? Sure, but to you want to build and paint a model or shade paint? It's one thing to add a bit of white to lighten a gray to look faded, quite another to match a Federal Standard color.
The second (of many) is pigment size. Model paint pigments have a very small particle size, enabling good coverage with a thin coat that doesn't obscure detail. Paint made for other purposes will have much coarser pigment, resulting in much thicker coats for the same coverage.
A lot more energy and time goes into the production and packaging of a model paint than a can of Rustoleum™. Part of what you are paying for is less of your time messing about with paint.
Thank you Jakko for mentioning me and my use of the cheapest craft paint available. Over the many years I've been at this hobby
I've used almost every "model paint" on the market at one time or another and the results were fine I guess. I even go back far enough
when the old Testors enamels which required thinners were the only game in town.
Then came out all the other stuff which I thought rather expensive, I mean "weathering powders" come on.
Get some dirt from the garden and some Elmers glue.
Mixing, yeah gotta do some mixing to get the tones right but what else have you got to do?
I use many, many layers and washes and am not gentle about it, after all what's 'gentle' about a tank or a wreck?
Jim.
In my opinion, your model finishes are much more artistic than those of most modellers: you're creating models and dioramas that look more like paintings of the real thing, than attempts to recreate the real thing in minute detail. Your choice of paints suits that style, if you ask me.
At our local IPMS show last quarter they guy who won best of show in the car category had one of the most amazing polishing jobs I've ever seen on a model. I chatted with him for a bit and he said he uses a cheapo clear coat from Walmart in a large rattle can. I was blown away.
Now, this material might not work on aircraft, I could see it filling in rivets and panel detail. But as far as being crystal clear and polishable (?) the results stood for themselves.
