LrdSatyr8 said:
I've started with the AMT Fiber Optic Kit a long time ago, but when they became harder and harder to find, I found the FiberOpticStore.com online and found that to get the same fibers that they use in that kit, you would need to get the 64 strand fiber cable. I ended up getting about 10 feet and it was alot cheaper then the AMT Kit that's for sure. The only thing about the kit that I like is that little drill with the micro drill bits. I think they re about an 85 I believe. Those drill bits are extremely fragile and break very easily if you don't watch yourself. They are harder to find then the fiber optic cable. Anyone know of a good source for those bits?
I don't, but I still have one that is functional, and I have been very careful with it. What I do now is use a Tamiya handy drill. It is very good on drill bits, even the small ones. The only thing is that the collet that comes with it won't hold a variety of drill bits. You will have to buy some dremel collets to fix this. (The dremel collets fit in the handy drill just fine.)
