TBadger
Demolitions Expert
- Mar 5, 2012
I came upon the realization that I lacked the basic accoutrement and tools of a decent photographer. My budget further impeded me getting the tools from the retail world. I searched the net and found some tents for anywhere from $30 for a small one barely large enough for a soda can to enormous ones that could fit a computer tower inside for over$250. These units didnt even include the lighting that you'd need to get it all running! So I went to Lowe's and picked up some cheap supplies to construct my own. Figure I would drop a tutorial in here just in case others wanted a much cheaper, effective solution to even lighting
Supplies: (2) 10' lengths of 1/2" CPVC pipe (I only used about 13.6 feet so it depends on your measurements )
(4) 1/2" CPVC 90 degree Street Elbows
(4) 1/2" CPVC Tee Elbows
(4) 1/2" CPVC End Caps
(1) Jar CPVC Cement
I wanted to make my Tent a 24" Square so I cut my piping into (4) 24" pieces with a Razor saw and i figured a suitable height would be 16" so I cut out (4) of those as well.
Starting Supplies
I sbegan by using the CPVC Cement to afix the endcaps onto the SHORT pieces I cut
I then glued the Tee junctions in place while using the table to keep the frame level
I dry fit the Street Elbows onto the frame and then glued them in place, letting the entire assembly dry about 30 minutes
* after dry fitting I marked the joints so i maintained alignment when gluing*
Once all was dried, I just slip the legs into the elbows and have a full standing frame ready to be draped and lit
** I DO NOT GLUE THE LEGS IN PLACE** THIS MAKES IT SEMI COLLAPSIBLE AND EASILY STORED IN A CLOSET WHEN NOT IN USE
Speaking of, I shall complete the build this evening and provide an update and some sample pictures to show the results of this endeavor.
-BADGER
(1) Jar CPVC Cement
Starting Supplies
-BADGER
