1/24 Sweets and Treats Shop
mustang1989
A couple of Christmas's ago, my wife and I were perusing the aisles at Hobby Lobby and I came upon this little scene in a box below:
She told me that this kit had my name written all over it and at first I was a bit skeptical because I usually either build cool looking autos or sinister looking aircraft or armor. The more I looked at it, however, the more I thought that this would be a cool little venture outside of my comfort zone. I decided to take the project on and over the course of the next few months would complete it to its end....which didn't turn out half bad.
All in all it wasn't a bad build aside from some parts in the kit that I just flat out didn't use.
1.) The Christmas tree in the box was crap so I tossed it in favor for one that I've had for one of my other shop dios during the holidays and it worked perfectly.
2.) There were like a bazillion packages that were supposed to be scattered on the ground in front of the shop and laying around all over the place and would've looked worse than my cluttered house garage did so I skipped out on about 50% of the packages.
3.) Cupcake construction was garbage so those didn't get built. I used the chocolates in bags and pastries to display in the glass covered enclosure on the counter.
4.) Vines and a Big Ol Bow on the sign on top of the building??..NO WAY!
5.) There is a front door with a handle and a side archway with no door??!
6.) Areas where I goofed was on the roof top panel and building squareness. I accidentally glued the roof panel on upside down with the unpainted side up. I was able to fix it by mixing some acrylic Rust and Cardinal Red together and got surprisingly close to the out of box color for the roof on the first try. I'll call that a win. I didn't pay close enough to building squareness when I put all of this together which exposed some of the checkered floor on the outside of the building. Simple fix as I just put some bordering at the bottom of the building to cover it.
Maybe I'm looking for as much (or at least getting it close) accuracy as I see in the kits that I build so I guess I'm not being all that fair.
lulz , yeah , I discovered that Sunday morning .
When I first clicked on this thread , only the first of the bottom 3 pix loaded , then I reloaded the page and the top pic appeared , 3rd reload they all showed ,,, except those emoji guys , where I figured you had photos .
We had issues with image posting in the DMs but it appeared confined to the DMs , so I thought the issue had maybe spread to the forum .
Thankfully not .
Thankfully not .
Nice. One of those sneak up behind you moments eh?
I've noticed the pictures don't show up all the time on my end as of late but it could be our firewalls here at work. To my knowledge nothing has changed as far as photo services here right Keith?
Image posting in the forum hasn't changed .
Blackbeard has been working on the site , he's been popping in an out so there might be some transient issues , but everything should be working normally .
Currently the only remaining issue in the DMs is posting a GIF from the wild -- the GIFs from the edit bar work but if you grab one off google images or something it will show until you hit post .
Blackbeard sent in a work order since it's one of those things that should be working but ain't
It looks really good!
I have to confess that my first thought was that you could put a soldier doing maintenance on a motorcycle, with sidecar, in the scene.
My second thought is that your wife will let you display it in a prominent place in the house!
Do you know if Eduard makes a photo-etched tea set for this scene?
Quinta Studio could make 3D cookie decals.
Kudos to you for stepping outside of your normal builds.
