Academy 1/72 F-8E Crusader
blakeh1
Usually I build aircraft gears up as I prefer seeing them in flight, but after picking up the Italeri 1/72 Carrier flight deck kit, I needed to start building a few gears down
I cut the wing flaps and repositioned to mimic a pre- take off type of position
still need to finish the decals and some weathering/fading but I was satisfied with the Light Gull Grey color.
Wound up using Vallejo's straight from the bottle.
I had done a custom mix with Tamiya paints on my previous 3 LIght Gull Grey color scheme with my 1/72 Academy F-14, F-4 and Hasegawa F-8
I also have to remove that "nub" on the tail fin. Apparently it is not supposed to be there, or is only there on later models or something?
looks good, as for the "nub" it may be a RWR or an IFF antenna. I know our F-15's had an antenna up on their vertical tail. Somebody out there must be a Crusader expert!
Finally finished this
Sat forever as a shelf queen, but putting it to rest and calling it done. Although I do need a base for it as this one is destined for an F-14
