'64 1/2 Mustang convertible - Monogram
C.A. Whitecloud
I primed, sanded/filled; primed, scribed and sanded. How many coats of primer is recommended? How smooth/shiny should my final primer coat be before starting my top coat? Black or grey primer under gloss burgundy?
Any last words before top coat? Tips/tricks? I'm really attempting to get my best finish yet. I followed a specific primer procedure. I did not sand the final black coat. It's pretty smooth to the touch. Where I get lost is how to judge when to wet sand/polish, how many coats in between and repeat the process more than once? How do you guys handle the engine bay and underside of hood? Using Rustoleum Burgundy rattle can.
I have to say I was pleased with myself for scribing of the molded wipers and getting a fairly clean line. First time trying aftermarket parts. Thought I'd start there.
All I can say is use multiple , light coats .
The primer looks grainy but it's hard to tell exactly from the photo .
It's smoother than it looks in the photo but I did purposely leave it with a bit of texture. Should I wet sand or something?
Do you have some fine grit sponge sanding sheets ?
I would do some sanding , but that's from what it looks like in the photo .
I have 2000 grit sponge. I have Micro-mesh squares but forgot what the different colors are. And what's the deal with wet sanding? How does it differ and when is it appropriate.
It's always appropriate when appropriate . lol
It's more efficient and gives a better finish since the water removes the waste .
2000 is really fine ; be like digging with a spoon -- especially against and alkyd . That's an enamel primer ?
I'd go with 6-800
going by the photo .
I'd go with 6-800
If I sand and it gets down to the grey layer does that mean my black primer coats are not thick enough?20231107_100337.jpg
gray layer ?
how many layers of paint are on this thing ? lol
Don't stand on the sanding sponge .
I was talking about just sanding down that pebble texture .
gray layer ?
I thought I was being gentle. I started with grey primer and then switched to black because I'm using Burgundy top coat.
I would have stuck with the lighter primer color .
So you're saying you've sanding through the black primer ?
I thought dark primer for dark colors. No?
It depends on the opacity of the topcoat .
You're using rattlecan enamels ( alkyd ) yeah ?
Acrylics provide far more translucence so the appearance of the topcoat can be modulated by the primer coat color .
Alkyds not so much .
If you did a comparison of that burgundy over grey and black primer you wouldn't see a difference .
That's why I said I would have stayed with the grey primer since each additional coat of paint can eliminate fine details .
Avoid excess coatings
One mist coat and another "mist" coat that went on a little wetter than intended. Do I apply more color coats? Do I polish and then more color. When do I know when to stop?
Looks Good !
Let that cure at least 24 .
