SimAir silent compressor, UK
helldiver
Styrene Addict
Very quiet, if you want to have a listen, pm me with your Tel no, I'll set up and I'll give you call for a listen. The carrying handle is the receiver so there is no pulsing. Pressure is regulated just under the gauge, moisture trap at the hose outlet. These are the sealed fridge like compressors that are oil filled and built to last. Oil will be removed for shipping. Automatic shut off in the event of over heating. A very handy foot operated power switch, leaving hands free. Keep meaning to add an in line foot switch to my own compressor! Another handy feature is drain points at both ends of the tank so that there is nowhere for moisture to collect. Serious bit of kit, change the oil every so often to the right level, drain the tank regularly and this will last for many years.For some reason, a rubber foot has been mislaid, easily enough fashioned. Will be sent myhermes, tracked and insured. £90 ovno
