Bill76
- Mar 3, 2013
Thanks guys for your kind words.
@Gag : compared to your future Goliath airship, mine is just David !
@ModelMadMike : the main oval hull is about 9,5 cm diameter (3,74 inches). When finished, the measures will be 13 cm (large with wings / 5,11 inches), 8 cm (height / 3,15 inches) and 14 cm (long from the light to the spoiler / 5,51 inches).
Last part of building concerns the inside cockpit. I've been looking for a while for a conic dashboard. And I find this cooking stuff ! This is used to seperate the white from the yellow when you break an egg to cook a cake ! I could be used to make a aircraft roof by the way.
I just keep the conic round part and this needs to be ajust. That part is shaped with my Unimat lathe. No difficuty for that except to ajust the size to the hull. The hole is about 2,5 cm / 0,98 inche diameter. The bottom side is made with an aspirin tube. I just need an headache as well to finish the tube ...
All the plastic parts are ajusted and glued with epoxy glue. Several round screens and joysticks are added to control Lulubelle.
Next step : painting.
[attachment deleted by admin]
