FAR T-33A 1961-1/48 Academy
spruecutter
Thanks, I have the fuselage together with 17 grams of weight in the nose. I can't figure why Academy left a gaping see through hole behind the 2nd pilots seat by the headrest. I saw a build elswhere and the modeler blanked it out with card stock. Also I don't think the back seater's seat is going to fit with the ejection rails on the seat. They made the rear seat area much smaller than the front. This should be interesting. See 2nd picture below for an explanation.
Down Time
What's "wordy"? Is that like "shirty"?
Sure, I held back explanation and opinion on a possible and obvious choice for a material to be used as a filler or to build a separation of a gap inherent to the fault of this model due to poor engineering by the manufacturer.
