'ere, what ya mean Pratmobile. Del Trotter Ford Capri.
Reaction score
[youtube]https://www.youtube.com/watch?v=uTrnfTGz6Aw[/youtube]
After a year & a half, ive finally stopped my wife from nagging me & found a Ford Capri model kit to convert into a Del Boy Ford Capri from Only Fools & Horses.
Picking up a pre-built Monogram Ford Capri II kit from a seller on ebay, whilst taking it apart I discovered that the seller had used what looks like superglue to put it together & whilst it came apart very easily, I was shocked to see he hadnt done anything with it.
No painting & no interior decoration, well that is all about to change.
Glueing the clear windshield & rear window into place with my glue n glaze & getting the main shell for primer with masking tape, when I sprayed with the primer the shell instantly looked a million times better with just the primer.
Then came the interior, after I primered that too I started on the seat covers with the tigerprint decals sheets.
Starting with the back seats, I created some templates with some microwave pizza box card & drew around with a pencil onto the decal paper & cut them out.
Using Microset & Microsol, I then placed the decals onto the seats (which was quite easy) & just used some of the offcuts for patching up around the edges.
Same principle for the door panels, but using some greaseproof paper as tracing paper, I then traced around the side panel inserts & cut them out & applied them to go around the border of the inserts & again patched up with some offcuts.
The dashboard was a little bit of a problem, but the Microset/sol did its job around those difficult corners, I decided not to decal the instument panel, as it was very fiddly & trying to cut around the dials didnt work out, so I removed the decals & painted in black with the dials in white & drybrushed in silver to bring out the detail.
Then came the task of the front seats.
Basically cutting out a square for the seat & a rectangle for the backrest, with a wraparound for the back of the seat & the sides of the seats, with another wraparound & a little hat for the headrests.
Was very fiddly indeed & using some more offcuts to patch up here & there, the final result is not too bad, even if the headrest so looks a little square instead of rounded, but once the shell is on top, hopefully they wont be noticable.
Once I sealed the interior, I started on the bodyshell.
Masking off the car apart from the roof & a little on the side, I sprayed with Halfords gloss black, once dry I took all the tape & newspaper & masked off where id sprayed black & sprayed the rest of the car with Humbrol 38 Lime Green.
Then I sprayed the underneath chassis in Halford gloss black & picked out the prop shaft, exhausts & the fuel tank in silver, which will be rusted up later on.
All-in-all so far the Capri is looking a helluva lot better.
Cheers,
Wayne.
Reaction score
Re: Del Boy Ford Capri
[youtube]https://www.youtube.com/watch?v=fXKaMuh2EFc[/youtube]
Well, Delboy's Capri is finished.
Ive started by lining up the 3 pinstripes on each side using the pinstripe decals I bought from Kitform Services, then I discovered the pinstripes wern't long enough.
So I had to overlap the line by cutting a pinstripe in half to make sure it went the full length of the car.
Soaking the pinstripe decals only took a mere few seconds to get them off the backing paper.
So, 6 times later I left them to dry & sealed them with some Humbrol Glosscote, however I didnt use Microset or Microsol on the pinstripes as they were a bit flimsy, so on the safe side I just used water.
Whilst the lines aren't perfectly 100% straight, they are straight enough for me.
I started where I left off with the mainbody shell by glueing in the underneath chassis, which clipped in at the rear & the mounting pegs with holes underneath the bonnet.
The front bumper plate had to be modified slightly, as the whole plate wouldnt glue back into place, so I cut off the side wheelarch bottoms & the front section for the bumper.
Throwing away the offending peice, I glued the 3 pieces into place & glued the bumper onto the front section.
Then I glued the last 2 rally headlamps into place underneath the bumper into the 2 holes I already drilled.
As I couldnt get some spare 6mm lenses for the headlights, I managed to get some 5mm transparent seaquins, glued those onto the front grill using the glue n glaze & they dried clear, so they worked out an absolute treat.
Using my push drill, I drilled 0.6mm holes (2 on the back, 1 on the bonnet) for the aerials using foodties.
I melted the plastic off the ties on my cooker, waited for them to cool, painted the silver & then the flourescent pink & put them inside the holes & glued them into place.
Then came the rear view mirrors.
The interior mirror was just a little of my sheet sign plastic, glued to one of those spare washers from my AT-ST, painted black on one side with silver on the other (to replicate the mirror) & glued to a piece of paperclip into another spare washer on the roof.
The hanging dice from the mirror were some sponge painted with white paint to make them go crusty, cut into 2 squares with 1 painted Tamiya X-15 green & the other painted in the flourescent pink, with little black dots painted on with a paperclip end.
I then jabbed each of the dice with a needle & thread, knotted underneath the dice a few times & hanged them onto the mirror.
The side mirrors are old ammo boxes from my Humvee build a couple of years back, I cut them in half down & using my dremel, I grinded a channel into the ammobox & glued in a small peice of a paperclip, filled the remaining of the channel in with some putty, sanded them down, then painted them flourescent pink & silver for the mirrors.
Mounted those into the side of the doors into the holes I pre-drilled & glued them into place.
I made some windscreen wipers using a little of the sheet sign plastic & some rubbers strips for the wipers, painted the arms in silver & the flourescent pink & glued those into place.
Last but not least were the numberplates, they were self adhesive & were mounted onto some microwave pizza card & using a combination of doulesided-sticky tape & glue 'n glaze they were mounted into their respective places.
My wife is happy on how the Capri tuned out, so Im happy.
Cheers,
Wayne.
urumomo
Reaction score
265
What is microwave pizza card ?
this build is making me hungry
.... maybe you show in video ,... be watching those momentarily 8)
Reaction score
The outer box that you get your microwave pizza in, I just cut a flap off the box and used it to mount my licence plate onto.
Because the card is very thin, but sturdy.
urumomo
Reaction score
265
All right , back from the vids .
Microsol Rules indeed !
Those decals are crazy but they must be good quality .
You have to be careful with the Sol as it will make short work of disintegrating some lesser decals .
Thanks for the trip across the pond ;D
I had to Wiki Only Fools and Horses , haha
Cool job with the fuzzy dice , BTW . That was a good idea .
Ciao ,
Mo
Ace
Reaction score
Enjoyed videos; c!ever scratch building with fuzzy dice etc. We got the show here (California) for a bit long ago.. Forgot the actor who played Rodney was the guy me and my wife hate on New Tricks...
