BSC 1/48 Harrier.
Reaction score
3
Given the long service record of this bird, they may have swapped tire manufacturers at some point. My bird has blank tires (but it is a 1/72 scale, so that sort of detail is a little unrealistic). In the end, I really don't think it will matter a whole bunch which wheel set you use.
Check this link out for some super-detailing documents/instructions and reference photos: http://harriersig.org.uk/
Hope this helps!
Peppylepugh
Reaction score
Aeroteto,
That is coming along very well. Very sharp, and 'clean'
if you know what I mean. I remember this WIP from
earlier in the year. Yeap, very sharp.
schweinhund227
Reaction score
Nice to see you go to TOWN on this....
the Bay is looking really nice ! what sort of juice did you use to weather it ?
nice and grimy !
Grendels
Reaction score
9
This kit is coming along. While I don't know a thing about the tires on this bird, I personally would use the Monogram tires.
Chris S
Reaction score
This is looking very nice . I like the detail & weathering in the wheel bays ...good stuff :)
PANZERMAN
My Karma ran over my Dogma.
Reaction score
Excellent work. The extra details really "PoP". I agree with you, the Monogram tire
looks better...go with that...have fun and keep building. Bill
Aeroteto
Reaction score
thank you very much guys!! ;D
It´s very warm and sunny here in Mexico, so I didn´t made any building in some time.
After glueing the fuselage together, check the wing asembly, it needs a little persuation by light sanding here and there.
Finally it falls together and everything looks good.
The intake have many seams and big holes so it looks a daunting task to fill all of them and get the whole intake area smooth, not impossible but too much work, and I want this model done ASAP.
So put some low tack tape on the intake area, mix some Krazy-Glue brand epoxy putty and press the lips of the intake to get the general forms.
I let cure the epoxy overnight and carefully remove them.
they looks very good, and need only a light fill and sanding for the intake covers I want.
I read somewhere that if you glue the lower wing halves first, you´ll get a tight joint avoiding a nasty seam in along the lower wing root.
so I did it that way and looks very good, but still have a seam in the flaps where they meets with the fuselage.
Also I glue a spacer in the fron LEX, I really don´t know why, it look the same to me, but I´m taking all the advice I can get.
Grendels
Reaction score
9
Nice bit of progress there. Good idea with the putty to make the intake covers.
JMac
cut. glue. paint. repeat.
Reaction score
Great work on the office, looking forward to the rest of the build updates.
Aeroteto
Reaction score
To correct the *Hasegawa kink* in the wings I will use the technique of Craig Sargent.
I will cut lower wing halves and folding the top.
But enough persuation need to achieve the fold.
So I put liquid cement in the saw cut, to soften the plastic, and a piece of streched sprue, then tape the wing to keep the angle till the cement dries.
All this leaves a small rib that needs to be sanded later, not big deal.
Aeroteto
Reaction score
Not big update here, work has been a beast.
I just noticed the weak detail on the gun so it was reworked a little.
Quaralane
Reaction score
110
It's a little thing, but it will definitely help the overall look
