Alclad Airbrush specs & info
Redfroghobbies
Ok, here are the descriptions for the new Alclad Airbrushes. As you can see, they include some extra goodies and are also priced very well
Alclad single action Internal mix
Item Number: ALC-9200
Description: Alclad Accurate Airbrush is the simple to use fine spray airbrush. Single action simplicity-Internal mix fine dot color atomization. Excellent for fine scale model finishing. Sprays from 0.5m
m to 2" spray pattern. Ideal for all Alclad products.This airbrush is set for consistent spray use after use.Set includes Alclad Accurate airbrush,Braided air hose,Flush fitting color cup and bottle adapter for Alclad 1oz bottles
Alclad precision Airbush
Item Number: ALC-9220
Description: Alclad Precision Airbrush is the easy to use detail spray airbrush. Single action simplicity-Internal mix extremely fine dot color atomization.Paint flow adjusting system enables repeatably accuracy time after time. Excellent for fine scale model finishing, model detailing etc. Sprays from 0.3mm to 2" spray pattern. Ideal for all Alclad products.This airbrush is set for consistent spray use after use.Set includes Alclad Accurate airbrush,Braided air hose,Flush fitting color cup and bottle adapter for Alclad 1oz bottles
http://www.redfroghobbies.com/products.php?cat=44&scat=341&prodline=AirBrushes
