1966 Ford Mustang 350GT R Finished
fightnjoe
i keep turning up....just like a bad penny....
Reaction score
4
Well folks I needed something to fill between build commitments.
This is the subject.
I will be posting some spru shots very soon.
Joe
fightnjoe
Reaction score
4
Re: 1966 Ford Mustang 350GT R
The spru shots.
Actually Pretty good detail with this one.
And the decals.
And to be honest I have begun. I have begun the painting of the body.
Joe
fightnjoe
Reaction score
4
The first two layers of the painting.
First was a layer of Testors Gloss Black. Once dry I sanded it out a bit with 1000 grit to get some of the blemishes to minimize. I then sprayed Alclad Polished Aluminium to give it a "metal" base layer.
After this I went with the first color. Model Master Enamel Artict Blue Metal Flake. I will allow this to dry then I plan to move into sanding out some of the blemishes that have occured. I will then hit it with another coat. I plan to build up the paint and then on to clear.
All comments, critiques, and criticism are encouraged.
Joe
fightnjoe
Reaction score
4
The body has color.
The color is Model Master Artic Blue Metal Flake.
Decals are now also on. They are setting up and I will have pictures soon.
Joe
fightnjoe
Reaction score
4
The decals went on ok.
All things considered though if faced with the same situation I would paint them on. As it is they are on and have been glossed. I was planning to polishing this up but I believe I will just leave it. It has a decent shine to it and looks pretty good.
So here are pics of the decals.
With those now done I can begin to work on the actual stuff in the instructions.
Joe
urumomo
Reaction score
125
The decals look really good from here .
Sounds like you had some trouble with them ?
Quaralane
Reaction score
48
Body's definitely looking good, Joe
fightnjoe
Reaction score
4
Many many thanks.
I did have some issue with the decals. Some appeared to be short for the area they were to be applied. Some were much too long. No worries though. Got through it.
Joe
fightnjoe
Reaction score
4
A small update.
The under parts and the interior tub get some paint and a bit of drybrushing. Semi Gloss Black, Model Master Metalizer Stainless Steel, and then Testors Flat Aluminium.
Next will be detail work on the under parts and such.
Joe
fightnjoe
Reaction score
4
Well after a bit of a lengthy break I am back.
Work continues on the Mustang with engine work, chassis work, and work on the interior. Trying my hand at wiring the engine again. Hope it works better than the last time.
Next up is to finish with the plug wires and assorted wires and cables.
Til the next time.
Joe
fightnjoe
Reaction score
4
We have a rolling chassis. The engine is now installed as well.
Next is to mate the body to the chassis.
Joe
Quaralane
Reaction score
48
Coming along very nicely here
fightnjoe
Reaction score
4
And she is finished.
All told it turned out much better than the first time I did up this kit.
Next up will be a couple of things that will test me to no end.
Joe
fightnjoe
Reaction score
4
Very kind. Thank you.
Joe
the Baron
Reaction score
19
Beautiful finish! The blue flake looks really good.
