Author Topic: [FIN] Airfix 1/48 - Hawker Hurricane  (Read 2037 times)
Offline DreamKnight
  • Admin
  • Overdose
    • Awards
« on: Tue Jan, 19, 2010, 04:38:AM »
Woot. In a couple of hours was pretty accurate. lol  So here's my Hawker Hurricane.  Never did an Airfix model before. Not sure if I'm really liking it but I guess you get what you pay for. lol Raise panel lines so I'm going to have to do some good deal of scribing.
« Last Edit: Wed Jul, 21, 2010, 03:18:AM by DreamKnight »
Want more scale model videos? Check it out! DreamKnight's Scale Model Videos
Offline Shark
  • Addict
    • Awards
Re: Battle of Britain - Air Superiority: Nerd Herd Group Build
« Reply #1 on: Tue Jan, 19, 2010, 08:10:AM »
What technique do you use to keep your scribes straight?  I always have trouble, "jumping out of the groove."
It's a trap!
Offline DreamKnight
  • Admin
  • Overdose
    • Awards
« Reply #2 on: Tue Jan, 19, 2010, 02:30:PM »
for the messschmitt I'm working on, I usually just follow the old lines VERY carefully. lol but sometimes I jump out of it bt then I started to use I use a card from a card game to guide the blade. lol You can just use any playing card.  The best way of course is to use a scribing template though. It's metala nd very bendable.
For straight lines, I use the tamiya scriber II and for little details like circles I put sewing needle in my pin vice.  I need to purchase a couple of templates like these though to make my job easier:
http://store.spruebrothers.com/172-verlinden-scribing-template-280-p1697.aspx
http://store.spruebrothers.com/135-voyager-scribing-template-set-1-tez027-p14512.aspx
http://store.spruebrothers.com/135-voyager-scribing-template-set-2-tez028-p14513.aspx
http://store.spruebrothers.com/135-voyager-scribing-template-set-3-tez029-p14514.aspx
Offline JMac
  • Overdose
  • Country: ca
  • It was like so, but wasn't.
  • Awards SILVER PLACE WINNER in the 2011 BIG Spring Contest
    • Awards
« Reply #3 on: Wed Jan, 20, 2010, 12:41:AM »
Here's a good scribing article - I found it helpful.
http://scihighmodels.com/howto_scrib.html
And I'd like to join in on the group build here. Not sure if I'll finish on time, but I'm going to try real hard to make the deadline...
Currently working on;
My BIG SPRING CONTEST SURPRISE BUILD!!!!!!!
1:72 CC-130 :P
1:48 Grumman Skyrocket * 1:48 BF 109 T-2
Vulcan Shuttle * Cardassian Galor
T-Rex * Horizon Invisible man * my old Battletech mini's & Some kind of anime walker thing of doom
Offline DreamKnight
  • Admin
  • Overdose
    • Awards
« Reply #4 on: Thu Jan, 21, 2010, 04:56:AM »
OK so I've worked on the wing section.  Lots of light sanding and then scribing.  Some area are kinda sloppy on the account of trying to go without a guide but I ended up using a plastic ruler. Was just too hard to keep straight lines without a guide.  The "divots" looks deeper than they are in the pic because of the angle I did the close up shots.  It isn't that deep.  The more crooked lines shouldn't look that bad once paint and weathering goes on though (I'm hoping anyways from experience lol)
Offline Shark
  • Addict
    • Awards
« Reply #5 on: Sun Jan, 24, 2010, 08:00:PM »
Nice start!
It's a trap!
Offline DreamKnight
  • Admin
  • Overdose
    • Awards
« Reply #6 on: Thu Jan, 28, 2010, 11:06:AM »
Reposting some updates:
Using aftermarket seats, going to have to cut the canopy in 1/2 and need to put more details in the exhausts adding screens to both and drilling into the small exhaust for some depth.
And the latest pics on the hurricane.  Scribed the fuselage, assembled the wing piece together, assembled the propeller.
Offline DreamKnight
  • Admin
  • Overdose
    • Awards
« Reply #7 on: Thu Jan, 28, 2010, 11:21:AM »
Woot! Got the seats in.  So I have to piece together the resin stuff with the original cockpit backing it looks like:
Everything put together and airbrushed it cockpit green.  Just have to paint in the details and apply a little weathering:
Offline DreamKnight
  • Admin
  • Overdose
    • Awards
« Reply #8 on: Fri Jan, 29, 2010, 05:39:PM »
OK so here's the seat with details and some weathering done to it:
The side walls of the cockpit.  One side was kinda bare so I looked up some pics and stuck in a container box and a pipe.
I was looking through some other pics and noticed the floor should actually suspended.  I definately can't go all the way through since on the other side is the wheel bay so I'll try to just carve the shape out and fill it out with black and see if I can give it the illusion of being suspended.  Also gonna have to stick some pedal straps on the pedals. I painted the areas I wanna curve out.
And for some reason, I've lost the gunsight either that it never got packaged. So I shaped this thing outa magic sculpt and I'mma gonna have to try and make one:
Offline DreamKnight
  • Admin
  • Overdose
    • Awards
« Reply #9 on: Thu Feb, 04, 2010, 08:29:AM »
Some quick updates.
Here I made my gunsight.  Used a piece of magic sculpt that I've cut and sanded then cut out a piece of clear plastic from the canopy sprue and sanded that down and buffed it.  Attached it to the cockpit display.
And a pic of the canopy that I've cut into two.
Offline DreamKnight
  • Admin
  • Overdose
    • Awards
« Reply #10 on: Fri Feb, 05, 2010, 08:48:AM »
Oh man, I cracked my canopy! lol I was seeing if the canopy would fit after some sanding in open position and I pushed down a bit too hard. Great excuse to purchase and play with a vacuform canopy! lol
Chung
Offline the Baron
  • Needs Intervention
  • Ich bin ja, Herr, in Deiner Macht
    • Awards
« Reply #11 on: Fri Feb, 05, 2010, 06:05:PM »
Great subjects, guys!  I haven't had a chance to check in and see how it's going, you've made a lot of progress.
I saw that comments about Tamiya vs Airfix, and I'll step up to defend Airfix, since I'm a nostalgia builder.  Yes, the detail isn't what we expect today, because there is so much excellent tooling out there, from the giants like Tamiya and Hasegawa, or the smaller but exquisite makers like Accurate Miniatures, Eduard, Classic Airframes.  But look on it as a blank canvas, an opportunity to flex your scratchbuilding muscles, if you'd like to add more detail.  That's what we did, "back in the day".  (Believe or not, I'm not that old :D )
And if I may offer an additional tip to Dreamknight's question (I think it was his) about scribing, for the guide, some people use Dymo tape.  That's the tape that is used in old-fashioned label makers.  It's rigid enough to act as a guide, but it's flexible and can be laid down on curves.  You just take a piece and lay it on the surface to be scribed, and draw your scriber along the edge.  It really helps on curves like the Bf-109 fuselage.
I'd love to join in, but I'm afraid my modeling plate is full for the foreseable future :(
Regards,
Brad
Non nobis, Domine, sed nomini tuo da gloriam
Offline DreamKnight
  • Admin
  • Overdose
    • Awards
« Reply #12 on: Fri Feb, 05, 2010, 06:12:PM »
Hey Baron!
On the Dyno tape, if I can FIND any around here! lol I'll have to order them online but it's on my list.
Offline DreamKnight
  • Admin
  • Overdose
    • Awards
« Reply #13 on: Tue Feb, 09, 2010, 06:53:AM »
Updates on my hawker:
[youtube]http://www.youtube.com/watch?v=YeIrKXh0SIE[/youtube]
Offline the Baron
    • Awards
« Reply #14 on: Thu Feb, 11, 2010, 06:10:PM »
Hi, Chung, nice progress!
Hey Baron!
Is there an office supply store near you?  That's where I'd look, though I see now, Dymo has it's own website  :D
