Author Topic: Revell 1:48 F/A-18 Super Hornet build... My noob adventures  (Read 922 times)
Offline glennonrp
  • Recreational User
    • Awards
« on: Thu Jan, 12, 2012, 07:37:AM »
So, I'm building this mode.  I'm working on a Strike Eagle, too, but, I'm waiting for a replacement top fuselage.  So, this is my project.
I have built a few models but this is my first in a long time.  I will likely make a lot of mistakes.  But, I plan to have fun doing it.  Here's my progress:
Nose built.  Note the "seam filling" by CA glue.
Canopy parts masked with Parafilm.  I have no idea if that will work as I never did it before.
Cockpit built and painted with decal.
Thanks for looking!  Any comments or suggestions are welcome.  I know I have a lot to learn.
« Last Edit: Thu Jan, 12, 2012, 07:55:AM by glennonrp »
Offline Carsenault
  • Needs Intervention
    • Awards
Re: Revell 1:48 F/A-18 Super Hornet build... My noob adventures
« Reply #1 on: Thu Jan, 12, 2012, 01:47:PM »
Only issue I see so far is the joint of the upper nose piece to the forward  fuselage halves. I'd address the fit first or there may be more fit problems afterwards.  great work on the cockpit, been building model aircraft for ages and I still struggle with the interiors. And I've tried many times to use parafilm to mask canopies bujt I have never been sucessful, they never stick on properly. Wondering if I am working/stretching the stuff too much.
Your on the right path, having fun is the first priority...
Online adampolo13
  • Addict
  • Country: us
    • Awards
« Reply #2 on: Thu Jan, 12, 2012, 05:18:PM »
glennonrp, great work on that cockpit!!!
Offline glennonrp
  • Recreational User
    • Awards
« Reply #3 on: Fri Jan, 13, 2012, 07:01:AM »
Would you mind being a bit more specific about the seam issue?  I'm not sure what you mean.  Do you have a suggestion on a way to handle this issue?  Is it the seam in the pic?  Thanks for the feedback!
I'll let you know how the Parafilm goes.
Offline glennonrp
  • Recreational User
    • Awards
« Reply #4 on: Fri Jan, 13, 2012, 07:05:AM »
Thanks, Adam!
A little update: I picked up a Touch-n-Flow  and played with it tonight.  I tried using Tenax 7R with it but I might have just been doing it wrong because it was dripping like crazy.  Or, it's just too thin for the applicator.  I spilled a bunch of the Plastic Weld that came with the TnF, too, trying to fill it.  I think I figured out how not to spill now, though.
A little painting was done of the air intakes and turbines.  The cockpit got glued in place.
Offline Carsenault
    • Awards
« Reply #5 on: Fri Jan, 13, 2012, 06:48:PM »
I have the same kit in my "to build" pile, havent touched it yet, though I may do it soon to go back to my comfort zone for a while.
The seam I am referring to is in this picture...
Its the joint between part #93 (nose top) and part #3 (fuselage front right half). the seam alkong the front edge of the nose top looks great, but it looks like there may be a bit of a step there at the back part of the seam, or it may need to be just filled with some putty. The parts should sit flush with each other. If they are not lined up right with each other, you may have trouble installing the front windscreen. if you do fill that gap with putty, remember to rescribe the panel line that would be there. if it is out of step, you might be able to get away with just applying some more liquid cemnet tothe joint, then after a few seconds, work the parts to re alling them. Hope this helps.
« Last Edit: Fri Jan, 13, 2012, 06:50:PM by Carsenault »
Offline glennonrp
  • Recreational User
    • Awards
« Reply #6 on: Fri Jan, 13, 2012, 06:58:PM »
Okay, that's what I thought you were talking about.  I used CA glue for that joint.  Is there a good way to work around that or is putty my only recourse?
Offline Carsenault
    • Awards
« Reply #7 on: Fri Jan, 13, 2012, 07:23:PM »
You can by a debonder for CA, if you just used a little bi, you might be able to just pop it int he freezer for a bit then it should be brittle enough to just snap apart cleanly. If that dont work, putty would be the best way to correct it.
CA is great stuff, but I never use it to join up the kit parts, it sets up too fast and does not give you time to line things up correctly. Proper plastic cement will allow you plenty of time to line everything up correctly, and for long seams, is one of the strongest adhesives. I use Tamiya extra thin for general model building and I use Tenax 7R for those really long seams when I am using a touch and flow applicator. Save the CA for attaching resin and photo etch parts to you kits.
Offline glennonrp
  • Recreational User
    • Awards
« Reply #8 on: Fri Jan, 13, 2012, 08:12:PM »
I just bought a Touch-N-Flow last night.  I think you're spot on about the different uses.  I was trying to see if I liked using the CA.  I thought it might fill the seam better.  I'll have to mess with the part tonight to see if I can realign it.  I don't want to use putty if I can avoid it so I can save the little details modeled into the plastic.  Thanks for the hints and clarifications.  I think I need to move more slowly and deliberately as I build.  I only get an hour here or there and I think I rush sometimes so I can show progress.
I also got a Flex-I-File and it did a great job with the nose seams.  Liking that tool a lot!
Offline Myke
  • Overdose
  • Country: 00
  • Awards GOLD PLACE WINNER in the 2011 BIG Spring Contest
    • No Cats Allowed
    • Awards
« Reply #9 on: Sun Jan, 15, 2012, 06:05:AM »
Cockpit looks great! Nice work.
Streaming live; my entire build process for all five entries into the Spring Contest at http://www.ustream.tv/channel/sma-spring-contest-2012#
Online schweinhund227
  • Overdose
  • Country: ca
  • Awards 	SILVER PLACE WINNER in the 2010 BIG Spring Contest 	BRONZE PLACE WINNER in the 2010 BIG Spring Contest GOLD PLACE WINNER in the 2011 BIG Spring Contest
    • Awards
« Reply #10 on: Mon Jan, 16, 2012, 03:13:AM »
 :o. Wow. That's gonna be a big Girl!
Keep up the good work!
No need to rush!  Take your time!    She will keep you busy for a while!
Offline glennonrp
  • Recreational User
    • Awards
« Reply #11 on: Mon Jan, 16, 2012, 07:02:AM »
Thanks, Schweinhund!  I got some work done these last couple days but haven't gotten pictures.  I built and installed the jet intakes, and the wing tips.  I painted the gear, wheels, and the radar pod thingy.  I also installed the aileron actuators and the missile pylons.  Since I got the TNF applicator, my joints are better.  This kit goes together pretty well and with good joints I barely need any filler that I can see.
I also realized I hadn't put Future on my canopy parts so I took the Parafilm off and dipped them.  I goofed the Parafilm on the little canopy and scratched it.  So, I polished out the scratch and dipped it again.  When it dries I will remask it.  I think I will hold off installing the landing gear so painting the body will be easier.  I will be painting it as soon as I get the canopy installed.
Thanks, Myke!  I hope the rest of my build looks halfway decent.
Offline Carsenault
    • Awards
« Reply #12 on: Mon Jan, 16, 2012, 02:08:PM »
Cool, now were talking. Hope to see sme pics soon.
Offline glennonrp
  • Recreational User
    • Awards
« Reply #13 on: Mon Jan, 16, 2012, 10:35:PM »
Tragedy strikes!
I appear to be missing some vital parts!  I already knew I was missing the nose gear landing light and the HUD, but I had resigned myself to either doing without or scratch building something from the left over sprue.  But, now I find that I am missing the canopy deck, and the left and right canopy frames.  I can't finish the canopy assembly without those parts.  So, I went online and ordered the replacements from Revell.  But, I also ordered a replacement fuselage for my F-15 that was malformed back on January 3 and I still haven't received it.  I don't expect to receive these parts before February.  Sigh.
I may start painting anyway.  I have to paint all the munitions, for one thing.  I could also paint the panel lines if I mask off the canopy area.  Heck, I could paint most of the plane if I do that.  So, I might.
Anyway, here's what I have so far:
The cockpit installed.
I had a seam line in the canopy.  But, this tri-grit polishing/finishing stick plus some 12000 grit polishing cloth took it out.
After I applied Future, it looked crystal clear!
Then I masked it again with Parafilm m and some Tamiya tape, just to be sure my edges were clean.
Here's the bird with some munitions and the centerline tank.
And the belly of the beast.
And a shot straight on.
That's the build so far.  Any comments or suggestions are welcomed.  Thanks for checking it out!  Hopefully someone will learn from my mistakes. :)
Offline Carsenault
    • Awards
« Reply #14 on: Tue Jan, 17, 2012, 03:12:AM »
Looks good, bummer about the missing bits though. Hopefully you wont have to wait too long to get the replacements. I kisy looked mine over to make everything was in there, looks complete as far as I can tell.
Odd bit in the instructions, not sure why they tell you to paint one canopy rail black, and the other grey, they should both be the salme color, more than likely black.
