Tue May, 22, 2012, 02:49:AM
Home
Forum
Login
Register
Search
SMA FORUM
The Hobby Link Japan Build Series
Reviews and Builds
(Moderators:
merseajohn
Chris S
TRM
SBD-1 Dauntless ...Hasegawa 1/48 limited Edition.
« previous
next »
Print
Pages:
1
12
13
14
15
16
21
Author
Topic: SBD-1 Dauntless ...Hasegawa 1/48 limited Edition. (Read 5228 times)
noname
Needs Intervention
Country:
Awards
Re: SBD-1 Dauntless ...Hasegawa 1/48 limited Edition.
Reply #195 on:
Tue Feb, 21, 2012, 12:59:PM »
Looking great Chris. The wash adds nice detail to those fine lines. Looking forward to seeing this finfished.
Logged
Myke
Overdose
Country:
Awards
Reply #196 on:
Tue Feb, 21, 2012, 03:36:PM »
The subtlety makes all the difference. A perfect layer of wash on that! The key to wiping it off like that is definitely having that smooth future coat on there.
Logged
Streaming live; my entire build process for all five entries into the Spring Contest at
http://www.ustream.tv/channel/sma-spring-contest-2012#
Ken Abrams
Admin
Overdose
Country:
I bleed olive drab
Awards
Reply #197 on:
Tue Feb, 21, 2012, 04:16:PM »
Very sharp, nice photos too.
Logged
I can row a boat, canoe?
Chris S
Moderator
Overdose
Country:
Awards
Reply #198 on:
Tue Feb, 21, 2012, 06:05:PM »
Thanks fella's
Glorfindel,Im happy if any of the techniques are useful too you
, and glad you learned something .
Myke ,you are quite correct ,a nice smooth coat does help a lot
Well ,I've got the Donkey and the undercrackers all fitted up ,also the engine cowling ....pics soon
Logged
http://www.youtube.com/user/ChrisSatTheBench
http://irishscalemodeller.com/
the Baron
Needs Intervention
Reply #199 on:
Thu Feb, 23, 2012, 06:24:PM »
Excellent job on the washes, and very instructive! I'm still getting the hang of them.
Logged
Non nobis, Domine, sed nomini tuo da gloriam
scratchmod
Needs Intervention
Reply #200 on:
Sat Feb, 25, 2012, 02:00:PM »
Chris I can only echo what the others have said. Another great use of the filter and great results as well bro. Waiting to see the dive brakes
Logged
http://modelerssocialclub.proboards.com/index.cgi
scratchmod. com
Chris S
Moderator
Overdose
Country:
Awards
Reply #201 on:
Sun Feb, 26, 2012, 12:06:AM »
Baron ,thanks buddy ,hope its useful to you
Rob ,Thanks bro ,didnt get much bench time today
so maybe tomorrow
Logged
scratchmod
Needs Intervention
Reply #202 on:
Sun Feb, 26, 2012, 03:52:PM »
no prob Chris, neither did I bro.
Logged
scratchmod. com
Chris S
Moderator
Overdose
Country:
Awards
Reply #203 on:
Tue Feb, 28, 2012, 11:47:PM »
Ok chaps ...Im getting there
The engine .....I decided to give this a simple dry brush with steel ,the hub casing was picked out with a neutral Grey ..as they normally are ,then a dark wash was used to settle the dry brushing a bit and I also added it to the casing but streaked it a bit .
After that the engine was fitted ,at the same time I fitted the gun barrels ,these were just painted black and high lighted with a smear of AK dark steel pigments .
Following that ,I picked out the edge of the firewall with silver ,this was not normally painted on the real thing as it acted like a heat shield for the exhaust ring ,but was left in the Stainless steel finish ,then ...The cowl was fitted .
Next up was the undercarraige ....very simple on the Dauntless ,just two legs ,these were painted with Aluminium along with the wheels ,then given a dark wash to bring out any detail .The tyres were painted with Vallejo German grey ,personally I think black is too dark .The legs locate positively into the wells ,and once in place I left them to dry up overnight .
Onto the Dive brakes / Flaps .....
These were painted the same way as the rest of the aircraft ,with the exception of the inside being painted Red ,for that I used Tamiya Flat Red ,you'll notice the spar has been left grey ...as it is on the real aircraft ,also the actuator rods are done grey .
To make fitting a bit simpler I fitted the rods to the lower flaps first rather than try to set them in after .The top Dive brake gets fitted first ,then the lower ,and as I had already done a dry fit ,I knew there was no fit issue ,so everything fell into place
A dark pin wash was also added around the ribs & spars on the inside faces .
And thats it for now ...I forgot to take some pics of the underside ,but I've more to do there so I'll take some then .
Thanks for looking.
http://www.hlj.com/product/HSG09953
Logged
Scott Girvan
Scale Model Addict
Admin
Overdose
Country:
Reply #204 on:
Tue Feb, 28, 2012, 11:54:PM »
This is a gorgeous build but man those drive brakes take to an entire new level.
Stunning.
Logged
Chris S
Moderator
Overdose
Country:
Awards
Reply #205 on:
Wed Feb, 29, 2012, 12:16:AM »
Thanks Scott ,but I honestly have to say a lot of credit goes to the kit ..its simply a great build and makes the job real easy
I'll get some better pics of the Dive brakes tomorrow ,I was a bit pushed for time when I took them .
Logged
TRM
Moderator
Overdose
Country:
Awards
Reply #206 on:
Wed Feb, 29, 2012, 12:23:AM »
Wow Chris!!! Dive Brakes!!!!! Yeah....just awesome!!!
Still can't get over those cool panel lines too!!!! Simply sexy!!!!!
Logged
Cheers!
T
Chris S
Moderator
Overdose
Country:
Awards
Reply #207 on:
Wed Feb, 29, 2012, 12:29:AM »
Thanks bro
....you're too kind
you doing ok ??
Logged
TRM
Moderator
Overdose
Country:
Awards
Reply #208 on:
Wed Feb, 29, 2012, 12:36:AM »
All is good...thanks!!! Thinking about the good times and trying to stay away from the idiots in the family starting things!!
Logged
Cheers!
T
Chris S
Moderator
Overdose
Country:
Awards
Reply #209 on:
Wed Feb, 29, 2012, 12:39:AM »
You're just right mate ,lie low and dont get involved ...works for me
Logged
Print
Pages:
1
12
13
14
15
16
21
« previous
next »
SMA FORUM
Reviews and Builds
(Moderators:
merseajohn
Chris S
TRM
