Author Topic: Trumpeter Cougar AVGP  (Read 3546 times)
Offline Myke
  • Overdose
  • Country: 00
  • Awards GOLD PLACE WINNER in the 2011 BIG Spring Contest
    • No Cats Allowed
    • Awards
Re: Trumpeter Cougar AVGP
« Reply #120 on: Mon Feb, 13, 2012, 05:05:PM »
A nice thin wash will give them that dusty appearance. You can build it up accordingly too. Not a bad idea to hit them with some soap and water first though.
Streaming live; my entire build process for all five entries into the Spring Contest at http://www.ustream.tv/channel/sma-spring-contest-2012#
Offline NecronautDrummer
  • Addict
    • Awards
« Reply #121 on: Tue Feb, 14, 2012, 08:07:AM »
Thanks for all the help with the tires, everyone!!
I sanded and washed the tires before mounting their hubs.  They're dry-fitted for now.  It sits level, and the tires are straight up and down, all in contact with the ground!  Thank goodness.  She's looking factory fresh right now.
I experimented with the shroud over the main gun a while back.  I remade it with tissue paper, painted it, gave it a wash with Citadel Gryphon Sepia, and highlighted it tonight.  The strap and buckle are all shiny stuff I raided from a PE set for my Spring Contest build.  I coated them with Tamiya brush-on Surface Primer in prep for painting.  I hope it passes muster, Ken!
And now for the ultimate exercise in patience... the barracuda cam net.  Right now, it's a sheet of tissue paper that's been brushed with scenic cement to stiffen it up a bit.  I'll be painting it in 3-color NATO cam tomorrow before I start the tedious process of punching out half-rounds with a cheap chisel I found at Michael's.  I hope to finish that in the next couple days as the clear coat hardens on the model in prep for filtering, washing, pigmenting, aka the fun part!
Happy modelling!   ;D  ;D
Online TRM
  • Staff Writer
  • Overdose
  • Country: us
  • Awards BEST OF SHOW WINNER in the 2011 BIG Spring Contest GOLD PLACE WINNER in the 2011 BIG Spring Contest
    • Modelers Social Club
    • Awards
« Reply #122 on: Tue Feb, 14, 2012, 09:11:AM »
Looking great ND!!!   Daunting tasks lie ahead...think you have it all under control!!!   Keep it going!!! ;)
Cheers!
T
Offline spud
  • Overdose
  • Country: ie
  • Irish and proud of it :)
    • irishbf2.net
    • Awards
« Reply #123 on: Tue Feb, 14, 2012, 11:01:AM »
She is looking mighty fine ND, can't wait to see that camo net
Offline Myke
  • Overdose
  • Country: 00
    • No Cats Allowed
    • Awards
« Reply #124 on: Tue Feb, 14, 2012, 11:46:PM »
looking fantabulous ...., I mean.... AWESOME!
  • Addict
    • Awards
« Reply #125 on: Wed Feb, 15, 2012, 12:33:AM »
I airbrushed the camo net in the standard Nato 3-color cam.  I was hoping it would bleed through to the other side of the tissue paper, but no luck.  It's drying overnight.  I won't get a chance to have a go at the underside until Thursday morning.  Meh.
Clear coat's on the girl, and she's ready for a filter!  Off I go!   ;D
  • Addict
    • Awards
« Reply #126 on: Wed Feb, 15, 2012, 06:52:AM »
And I'm back...
She got a filter from the AK NATO weathering set, and I'm applying a pin wash right now.  Never having done this before, I referred to an entry from Mig's blog where he weathers a front-end loader (it seemed the most straightforward how-to I could find).  He slops on a wash in the panel lines and stuff, then comes back later and cleans up the excess with a small brush dampened in spirits.  Easy-peasy!
So that's what I did.  I gave the entire hull a panel/detail wash, and I'm coming back after it's dried to scrub away the excess with a small brush & turpenoid (no fumes).  Thank goodness for the non-fume issue, because I've been at it for two hours, and what you see is all I managed to get clean.  The hull section in front of the driver hasn't been cleaned yet (you can still see excess wash around some bits).  I've watched several vids on YouTube on doing a pin wash, and they all just seem to dab or slop it on, and they never seem to clean up the excess.
My eyeballs are about to fall out of their sockets.  Is this normal for a pin wash?  And I mean the look, the amount of time it's taking, the tediousness, the eyestrain, everything.   ???
Offline spud
  • Overdose
  • Country: ie
    • irishbf2.net
    • Awards
« Reply #127 on: Wed Feb, 15, 2012, 12:51:PM »
get you hands on Washes, fading and oils from AK done by Mig Jimenez he shows you exactly how its done,
hmm googled for a link for you and found this on you tube, watch it while you can because im sure its not ment to be  there
*edit: video removed and thanks for your PM spud... no harm done but lets not promote copyright infringement  ;D
oh yes i Highly recomend you Buying the DVD, im sure this will get removed soon
as for you doing the whole thing, i think you done too much. i think you should only do 1 section at a time let it for 15min and clean then do teh next area. But the thinners should still clean the excess.
« Last Edit: Wed Feb, 15, 2012, 03:08:PM by Ken Abrams »
  • Addict
    • Awards
« Reply #128 on: Wed Feb, 15, 2012, 03:04:PM »
Yeah, I tried to order this with my AK fluids, but they were out of stock.  While it's very much appreciated, spud... my moral compass says no.  But I appreciate the help!!
Offline spud
  • Overdose
  • Country: ie
    • irishbf2.net
    • Awards
« Reply #129 on: Wed Feb, 15, 2012, 03:17:PM »
hehe good man ND i pmd Ken after posting to get it removed from youtube because it should not be up there, :) and ken thaks for removing the link i should have known better than to post it but ND was man enough not to watch it :)
ND i Highly reomend you finding a copy of it, Also the the one for the winter techiques as they are both fantastic and somthing you will watch more than once :)
Offline Ken Abrams
  • Admin
  • Overdose
  • Country: us
  • I bleed olive drab
  • Awards GOLD PLACE WINNER in the 2011 BIG Spring Contest SILVER PLACE WINNER in the 2011 BIG Spring Contest GOLD PLACE WINNER in the 2010 BIG Spring Contest
    • Camo's Corner
    • Awards
« Reply #130 on: Wed Feb, 15, 2012, 03:25:PM »
No worries man and thanks again.
I've already spoke to Iain about it and it's all up to youtube now and they're pretty slow at times...
I can row a boat, canoe?
Offline spud
  • Overdose
  • Country: ie
    • irishbf2.net
    • Awards
« Reply #131 on: Wed Feb, 15, 2012, 03:35:PM »
why am i not suprised about that. :) and your welcome ken.
  • Addict
    • Awards
« Reply #132 on: Fri Feb, 17, 2012, 06:26:AM »
So here's where I am right now:
Colour mod on the hull.  Haven't got to the turret yet.  I'll do that tomorrow evening and let it dry over the long weekend.  I started on the barracuda cam net too.  Should be finished soon!
BTW, is it too late to do the chipping?  ???
Happy modelling!   ;D
« Last Edit: Fri Feb, 17, 2012, 06:33:AM by NecronautDrummer »
Offline spud
  • Overdose
  • Country: ie
    • irishbf2.net
    • Awards
« Reply #133 on: Fri Feb, 17, 2012, 12:55:PM »
no you can do some now and just do some more weathering or blend it all in when you are finishing up
Offline panzerace007
  • Overdose
  • Country: us
    • Awards
« Reply #134 on: Fri Feb, 17, 2012, 10:14:PM »
ND,
   Lookin Good !! Rock-It brotha' !! Good stuff !!
