Quote from: Moon Puppy on Wed Jul, 27, 2011, 05:14:PMQuote from: Gundamhead on Wed Jul, 27, 2011, 04:28:PMThat's like using your Ferrari to haul lumber. Or bunches of hardbombs on a F15? Exactly. There was a reason for the 'F' designation. Air supremacy. You lose it's intended purpose trying to be a Jack of All Trades. The F-15E is more like a "A"-15E. The same happened to the F-14 and F-18. Shortsighted politicians trying to get one plane to do it all. The P-51 was designed as a Pursuit air supremacy fighter. Not an attack or bomber craft. There were just better planes for those roles. Just sayin' Keep mine in the fighter role.
Quote from: 13aceofspades13 on Wed Jul, 27, 2011, 05:09:PMno... i would not say it would be like hauling lumber with a farrari, the Mustang was heavier than most fighters, though it could out perform most fighters. the P-51 weighed in at about 11,000 all bombs rockets loaded on full internal load, about 9,500 with full internal load. about 8,700 with a reduced load. it could take hits from 30MM cannon and still fight... as long as it did not get hit somewhere super vital. it was a durable fighter, and fast at low level with a top speed of about 367MPH at sea level, faster than most fighters at low altitudes, and had good agility. it was actually most agile and easiest to fly at lower altitudes, beacuse of its laminar flow wings liked the thicker air. however it could take on 109s and 190s... at more than equal terms... It's exactly like stuffing lumber in your Ferrari. You really think 2 identical P-51s but one weighed down with all that extra ordinance is gonna be as good a fighting plane as the naked one? Weights aren't the issue, the affect of the weight on performance is.The unloded Ferrari is gonna clean the clock of the one hauling lumber.
Quote from: Gundamhead on Wed Jul, 27, 2011, 06:55:PMQuote from: 13aceofspades13 on Wed Jul, 27, 2011, 05:09:PMno... i would not say it would be like hauling lumber with a farrari, the Mustang was heavier than most fighters, though it could out perform most fighters. the P-51 weighed in at about 11,000 all bombs rockets loaded on full internal load, about 9,500 with full internal load. about 8,700 with a reduced load. it could take hits from 30MM cannon and still fight... as long as it did not get hit somewhere super vital. it was a durable fighter, and fast at low level with a top speed of about 367MPH at sea level, faster than most fighters at low altitudes, and had good agility. it was actually most agile and easiest to fly at lower altitudes, beacuse of its laminar flow wings liked the thicker air. however it could take on 109s and 190s... at more than equal terms... It's exactly like stuffing lumber in your Ferrari. You really think 2 identical P-51s but one weighed down with all that extra ordinance is gonna be as good a fighting plane as the naked one? Weights aren't the issue, the affect of the weight on performance is.The unloded Ferrari is gonna clean the clock of the one hauling lumber.i know this, and this is why if Mustangs where escorting bombers, they would not be mounted with bombs and rockets, and if they needed to engage an enemy, they could drop and or launch there ordnances... and engage. bombs where pretty much kept on hard points like drop tanks, bombs could be dropped like drop tanks. and the mustang had a range of 1,300 miles with all the internal tanks full, and the distance from London to Berlin and back is only about 1,200 miles and when a mustang would perform a attack role its target was typically closer then that!i guess the benefit of attacking a smaller target with fighters is the aircraft does not need escort, it can defend itself. and you don't need a group of bombers to perform something like air support, at the time it was easier to use fighters for air support rather than designing a attack aircraft. a fighters primary role in the ground attack role was typically air support, destroying tank columns (Tank Busters Squadron.) destroying truck convoys, locomotives, using a B-17 or even a B-26 for this would be over kill... now in my opinion if he wants to put bombs and rockets on his P-51 all the power too him.
Mine will be Canadian...just got to find the right markings!!
hold on guys just a second the mustang had a maximum range of 2,000 miles, with a pair of 108 gallon drop tanks on its wings, and a internal fuel range of 1,300 miles with about 269 gallons o fuel, in the two main tanks in the wings, and the one aft fuselage tank, sources to prove my findings... http://www.soseisberg.com/content.php?pagina_id=16http://warbirdsofww2.tripod.com/p-51.htmhttp://www.airventuremuseum.org/collection/aircraft/North%20American%20F-51D%20Mustang.aspmy website, is one of the first things that popped up, ironically beacuse nobody goes too it. http://13thace.forumotion.com/t6-p-51-mustang-my-favorite-aircrafthttp://military.discovery.com/technology/vehicles/fighters/fighters-01.htmlhttp://www.fantasyofflight.com/aircraftpages/p51c.htmthe mustang had a range of about 1,650 miles with the 75 gallon drop tanks, and later some time during the end or after the war they had ferry tanks that held about 165 gallons of fuel which would increase its range to about 2,500 miles, they never had drop tanks that carried 150 gallons of fuel buy my sources or buy what i understand, the more common drop tanks available are what are available in the kit, 75 gallon drop tanks and 108 gallon drop tanks.i never said the mustang escorted bombers with bombs and rockets, in fact i think i said they never did, beacuse there primary role at that point is to escort the bombers, bombs are dead useless and now you cant have drop tanks, and rockets, well they are useless agents other aircraft due to the lack of accuracy and aircraft performance degreadence, 4 to 6 .50 caliber machine guns with muzzle velocities of 2,700fps and rates of fire of 800 rounds per minute, would rip a little fighter to peaces, and would be far more effective rockets with a droopy and unpredictable trajectory. i am also aware that some of the bases where closer, or farther than England, or some enemy target are closer and farther, than Berlin, and i think i stated that, saying at times the target was closer than from Berlin to England. and at times thats how the mustang could easily do the ground attack role with bombs and rockets strapped it had the range... to perform roles such as air support, later in the war... bases in liberated Europe where taken over, and mustangs would also take off from them, but that was much later in the war. and i was also aware that bombers would travel a distance before the fighters would meet them, beacuse the fighters would travel so much slower than the bombers, that it would actually decrease there range, so it was best, to meet them some time later... at point B as you stated. my point over all however, P-51s where used frequently in the air support role, and they where equipped with bombs and rockets, and it would not be like hauling lumber with a farrari.
Operation range with drop tanks: 1300 miles
oh you B************* thats sweet. * spud is jelous
Quote from: spud on Thu Jul, 28, 2011, 12:43:AMoh you B************* thats sweet. * spud is jelousi know right, i am dying for this kit... but saving my money for other things right now... DXhay guys? does this kit come with a pilot? if so can you get a photo for me?
