Author Topic: Kyrathalia's Deathcry-custom lightsaber build  (Read 926 times)
Offline Quaralane
  • Overdose
    • Awards
« on: Mon May, 15, 2017, 12:20:AM »
All right, next up on the bench is a custom lightsaber hilt.
I'm naming it "Kyrathalia's Deathcry" after my Sith Sorceror in Star Wars: The Old Republic
It's going to be built using metal parts from The Custom Saber Shop's Modular Hilt System, electronics from Ultrasabers, and the pommel is a shower faucet handle from the Home Depot.
Blade will be a bright orange when I'm done
To get started, I mapped out the basics of the hilt design using TCSS MHS Builder
Once the parts arrived, I roughed out how the layout of the hilt would look in real life
A quick look at all of the components going into this build
Because of the way some of the parts were engineered, and with the LED module being already wired for a quick disconnect, I needed to modify the TCSS heat sink by opening up two of the side holes
Made an adapter from a nylon fitting that allowed me to connect the handle piece to the blank pommel section. This was all connected rather solidly with some JB Weld
Got the holes drilled and tapped for the covertec wheel in the grip, and blade retention screws in the emitter.
Also got the hole opened up for the switch housing.
The grip was partly masked off, as well as the thread section of the choke. These were then primered with flat black Krylon primer.
A coat of Testors Graphite Dust was added, and then they were hit with a coat of Kyrlon Crystal clear
Next up is a whole lot of electrical work
Youtube link:
« Last Edit: Mon May, 15, 2017, 12:48:AM by Quaralane »
Offline BenHobbie
  • Addict
    • Awards
Re: Kyrathalia's Deathcry-custom lightsaber build
« Reply #1 on: Wed May, 17, 2017, 11:39:AM »
Awesome work  ;)
If you need more advices I'm here ;)
Offline Quaralane
  • Overdose
    • Awards
« Reply #2 on: Thu May, 18, 2017, 12:12:AM »
Thanks, Ben.
I may be looking for that advice. May have things figured out now, though
Offline Quaralane
  • Overdose
    • Awards
« Reply #3 on: Sat May, 20, 2017, 07:35:PM »
Update on the buildup of "Kyrathalia's Deathcry"
Prior to installing the switch, I used my Dremel to make an inscription just above it.
The inscription, in Aurabesh font, reads "Peace is a lie," the first line of the Sith Code.
I printed it out on some blank decal paper and laid it on to act as a guide for the work.
That done, I scrubbed off the rest of the decal paper, and then highlighted the inscription with a black wash.
For the pommel, I opted to paint it up like a gem held in a metal mounting.
I painted the clear areas with a transparent orange, and then painted the 'claw' with Vallejo dark grey primer followed by Tamiya's Chrome Silver
Began wiring up the guts, including a trio of red LEDs for lighting up the pommel.
LIGHT test!
Initially, I had the wiring for my illuminated switch reversed. I fixed that and got ALMOST everything working.
Sadly, despite installing a resistor, my wiring job resulted in blowing the LEDs for the pommel
I sanded down the raised areas on the grip prior to assembly, along with adding some other sanding on the choke to add some weathering.
Got her all assembled, and then fired her up again.
We now have a finished lightsaber with a blazing orange blade
Finished build pics
Youtube link:
Offline Grendels
  • Mod
  • Overdose
    • small business that I own.
    • Awards
« Reply #4 on: Tue May, 30, 2017, 03:27:PM »
well done!
Offline Quaralane
  • Overdose
    • Awards
« Reply #5 on: Tue May, 30, 2017, 07:09:PM »
Thanks, John
Offline Jason Abbadon
  • Addict
    • Awards
« Reply #6 on: Sun Nov, 05, 2017, 01:32:AM »
So very badass.
Offline Quaralane
  • Overdose
    • Awards
« Reply #7 on: Sun Nov, 05, 2017, 12:15:PM »
Thank you, Jason.
It definitely laid the groundwork for the later build of 'Therion's Wrath.'
