Author Topic: Grendels lighting Tutorials  (Read 19932 times)
Offline Igard
  • Overdose
    • Awards
« Reply #16 on: Tue Oct, 18, 2011, 07:18:PM »
Good vids, Grendels. As you know I used the 555n timer for my Maquis Raider build. I can testify as to its juice guzzling!
That 4060 looks like it has some uses. Certainly much easier to wire than the 555.
- Iain
Offline Grendels
  • Mod
  • Overdose
    • small business that I own.
    • Awards
« Reply #17 on: Wed Oct, 19, 2011, 02:53:AM »
Much easier and low power to boot.  It is a nice chip for model building.   Cheap too!  I just got some off of ebay for $0.50 each
Offline Neo
  • Needs Intervention
  • What do you mean i'm addicted to Airplanes!
    • Scale Model Hangar
    • Awards
« Reply #18 on: Thu Nov, 03, 2011, 01:01:PM »
link ?
also there was a ebay link to a LED ebaystore selling cheap cnat find it anymore
Can wait to see the next video !! Great work
Offline Grendels
  • Mod
  • Overdose
    • Awards
« Reply #19 on: Thu Nov, 03, 2011, 03:23:PM »
Neo here is the Ebay store for the LED's:
http://stores.ebay.com/bestshop2008hk?_trksid=p4340.l2563
Search for the seller bestshop2008hk if the link doesn't work for you.
For the 4060 chip, what I did was an ebay search for 4060.   Stick to the electrical and test equipment category.
  Quite a few listings turn up.  Just make sure somewhere in the listings it says binary counter and you will be fine.  Here is one example:
http://www.ebay.com/itm/10-x-CD4060-4060-RIPPLE-CARRY-BINARY-COUNTER-IC-/260828020950?pt=LH_DefaultDomain_0&hash=item3cba8fc0d6#ht_1433wt_878
I have not purchased from them before, so I cannot say if they are any good.  The one I did purchase from was here in the USA.
Some of the Chinese sellers will sell them for $0.30 each when you buy 20 or more.  And they have free shipping!
Offline Neo
    • Awards
« Reply #20 on: Sun Nov, 06, 2011, 08:45:AM »
Thanks for the links thats perfect.
ive got another question..
Some on on ARC sugested some SMD lights have you ever tried these they look pretty cool. anything bad about using them ?
Cheers
Neo
« Last Edit: Sun Nov, 06, 2011, 05:58:PM by Quaralane »
Offline Quaralane
  • Overdose
    • Awards
« Reply #21 on: Sun Nov, 06, 2011, 05:58:PM »
Those things are TINY
Offline Grendels
  • Mod
  • Overdose
    • Awards
« Reply #22 on: Mon Nov, 07, 2011, 02:19:AM »
Neo,
   The only thing I know that is bad about them is their tiny size.  It makes it really hard to solder them to wires.  Other than that, I don't think there is anything wrong with them.
   I have actually thought of pulling a few off of old circuit boards before I trashed them.   Never did do it.
Offline Omegaman55
  • Recreational User
    • Awards
« Reply #23 on: Wed Nov, 30, 2011, 07:25:PM »
Hi Grendels,
What do you think to EL sheet/ribbon?
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=160691868151#ht_1419wt_689
I'm thinking of using it in my Falcon and would like to know any thoughts...
« Last Edit: Wed Nov, 30, 2011, 07:27:PM by Omegaman55 »
Offline Grendels
  • Mod
  • Overdose
    • Awards
« Reply #24 on: Thu Dec, 01, 2011, 06:35:AM »
I have never really worked with El sheets, but I have worked with El wire before.   It will dim out over time, and it isn't all that bright.   This was five years ago, so the product may have changed since then.   The only way to find out is to buy some and give it a try.
Offline Grendels
  • Mod
  • Overdose
    • Awards
« Reply #25 on: Wed Jan, 11, 2012, 02:47:AM »
Here is a new update, a Android app called Electrodroid.  It is a good resource for figuring out different things for working with electronics.
Lighting Tutorial: Electrodroid
Thank you ModelmanTom for finding this for me!
Offline Grendels
  • Mod
  • Overdose
    • Awards
« Reply #26 on: Fri Jan, 13, 2012, 04:40:PM »
The next installment:
Lighting tutorial: Different types of LED's
Only one more after this one.
Offline Grendels
  • Mod
  • Overdose
    • Awards
Re: Grendels lighting Tutorials
« Reply #27 on: Wed Jan, 25, 2012, 04:02:AM »
Here are the last four videos in the series:
Lighting Tutorial: 555 pros and cons
Links given in the video:
555 timer links
NX-01 build
555 infomation
On the right look for The 555 and read pages one and two
various circuits with the 555
And next building up the circuit:
Lighting Tutorial: The 555 build up
Strobing the 555:
Lighting Tutorial: Strobing the 555 timing chip
And a slide show of the circuits surrounding the 555:
Lighting Tutorial: 555 circuit slide show
Here is a link to all the circuits slides used in the show so you can print them:
circuit diagrams
« Last Edit: Thu Feb, 02, 2012, 04:44:PM by Grendels »
Offline fumblethumbs
    • Awards
« Reply #28 on: Wed Jan, 25, 2012, 04:36:PM »
That's money right there!  I've been waiting for Professor Grendels'  "555 Timer Strobe for Dummies"
Thank You Sir!
Offline Grendels
  • Mod
  • Overdose
    • Awards
« Reply #29 on: Thu Jan, 26, 2012, 01:47:AM »
Your welcome!
If you can follow this and build a few circuits, you will save a lot of money.
Parts and supplies are under $10 for what the pro's sell for close to $100.   You just have to learn and do it yourself.
