Author Topic: Grendels lighting Tutorials  (Read 25055 times)
Offline cobraleader
  • Addict
    • Cobraleader's Workbench
    • Awards
Re: Grendels lighting Tutorials
« Reply #105 on: Tue Aug, 23, 2016, 06:53:AM »
thanks Grendals ...
Thanks
cheers
Mark
"Who's the more foolish ?  The fool or the fool that follows him ?"
http://cobraleader.blogspot.com.au/
http://www.youtube.com/user/cobrawingman
Offline cobraleader
  • Addict
    • Awards
« Reply #106 on: Thu Sep, 22, 2016, 08:36:PM »
doing some research at work on the 555 chip ...
why use the 555 to create pulsing lights ???
could we not use a low value capacitor on the 4060 pin out for the led ?
when the 4060 timing chip cuts the power to the pin out, it would force the capacitor to disperse the power it's built up. thus the fade out of the led light ...
the same should happen when the timing chip sends power the pin out ...
i'll try this later tonight, to see if it works, just after some feedback before I try.
Thanks
cheers
Mark
Offline Grendels
  • Mod
  • Overdose
    • small business that I own.
    • Awards
« Reply #107 on: Fri Sep, 23, 2016, 01:01:PM »
I don't know if that will work.   I know you can slowly fade LED's with the 555, but I am not sure with the 4060.   The 4060 is a digitial chip, while the 555 is not.    That might be the reason. why most use the 555 to fade LED and not the 4060
