Author Topic: Your best quick tip/technique/diy  (Read 35462 times)
Offline Scott Girvan
  • Scale Model Addict
  • Admin
  • Overdose
    • www.scalemodeladdict.com
    • Awards
« on: Thu Sep, 29, 2011, 08:26:PM »
Hi,
Looking to put together a list of quick tips, technique and DIY items. Short and sweet ideas.
I'll start with a few easy ones:
 - Save old toothbrushes to use for cleaning and scrubbing parts when washing them up before a build.
 - When spraying Vallejo paint, keep a damp, soft rag handy to gently clean the airbrush tip.
 - When using Tamiya thin glue, less is often more. Too much will cause longer dry/bond time.
 - Toothpicks are often better than paintbrushes to painting small detail, like in a jet's cockpit
You got some?
Offline Jeeves
  • Needs Intervention
    • BigDaddyModeler
    • Awards
Re: Your best quick tip/technique/diy
« Reply #1 on: Thu Sep, 29, 2011, 08:55:PM »
If you or someone you know wears contact lenses, the foil cover are a great source for belts and straps and the well the lenses sit in make great disposable paint palettes...
Offline spud
  • Overdose
  • Irish and proud of it :)
    • irishscalemodeller
    • Awards
« Reply #2 on: Thu Sep, 29, 2011, 09:00:PM »
old messed up paint brush makes for great grass to mix with mud.
Offline Quaralane
  • Overdose
    • Awards
« Reply #3 on: Thu Sep, 29, 2011, 10:17:PM »
Old CDs make excellent paint pallets
Offline Grendels
  • Mod
  • Overdose
    • small business that I own.
    • Awards
« Reply #4 on: Thu Sep, 29, 2011, 11:20:PM »
bottle caps make a great paint mixing cup
Offline Igard
  • Overdose
    • Awards
« Reply #5 on: Sat Oct, 01, 2011, 04:31:PM »
Thank you, Jeeves. I'm a contact lens wearer. Being the 1st day of the new month, I'm opening a new pair tonight. This time, I'll not throw anything away!  ;)
You can also use the contact lens solution bottle for storing liquids. They're great for dispensing in small, 1 drop amounts.
- Iain
Offline 13aceofspades13
  • Overdose
  • lets kick some tires and lights some fires!
    • Aces Air Hanger
    • Awards
« Reply #6 on: Tue Oct, 04, 2011, 10:48:PM »
painting a engine flat black, then dry brushing silver over it gives it a great weathered look, and brings out the details, most especually if its a air cooled engine like my Hellcats R-2800-10
Aves is good for adding features too your figures
aves parachute...
Offline YOULI
  • That which does not kill us makes us stronger !
    • Awards
« Reply #7 on: Wed Jan, 04, 2012, 11:35:AM »
Wooden spoons and ice cream picks make the perfect tools to dispose Tamiya Putty even in small areas. Same way than with Toothpicks only with a larger surface to apply...
Demineralised water with a drop of soap dish make the perfect liquid to use acrylic paint (it gains in fluidity and the brushes marks are almost invisible).
Save the Citadel normal glue recipient. You can remove the apllicator easily, remove the dry glue in it and replace it with, in my case, alcohol 90°. An easy way to count drops in your paint for example.
You have a broken or unable to use airbrush pin... Use it with an old criterium (don't know the englisgh name of it) instead of using big "mines" it's even better if you have the old aluminium ones. It makes the perfect engraver tool !
Save the old dry paint. Acrylic or Enamel, you can use it for your dioramas, once you break it in small pieces.
I've got a lot of other tips, but it's difficult to explain it in english :D
2272 model kits and counting...
Offline Black Sheep 1
  • disgruntled member
    • Awards
« Reply #8 on: Tue Jan, 10, 2012, 08:26:PM »
If you eat at KFC, those little containers you get your Mac & Cheese and coleslaw are great for paint palettes, as a decal soaking container or as a container for cleaning your paint brushes after you're done painting.
On the bench:
Offline fumblethumbs
    • Awards
« Reply #9 on: Tue Jan, 10, 2012, 09:03:PM »
After sanding down the joint seam on tire treads, I use the nylon brush wheel in the dremel to clean out the tread grooves.
The siphon pot lid for Badger airbrushes thread onto Tamiya acrylic paint jars.
Offline Dusky
    • Awards
« Reply #10 on: Sat Jan, 14, 2012, 09:34:PM »
Cut AWAY from your body with no part of your body in the path of the blade.
You can cut a slit in the end of a toothpick that will help it hold more paint or glue/cement.
Offline Grendels
  • Mod
  • Overdose
    • Awards
« Reply #11 on: Sun Jan, 15, 2012, 01:36:AM »
I think this needs to be shared over in the model related injuries thread....
Offline RocketSilo
  • Addict
    • Awards
« Reply #12 on: Mon Jan, 16, 2012, 06:58:PM »
A tip I just learned recently and never thought of.
Always store your good paint brushes tip down after cleaning, it keeps solvents and such from settling in the ferrule and loosening the adhesive/hairs
 install the protective tubes to support the bristles when storing this way.
Offline YOULI
    • Awards
« Reply #13 on: Mon Jan, 16, 2012, 08:22:PM »
If you don't have protective tubes, use Straws :D
Offline spud
  • Overdose
    • Awards
« Reply #14 on: Mon Jan, 16, 2012, 09:30:PM »
have you ever knocked over your pot of glue, I have twice, get somthing to widen the base next time you knock up agesnt it it wont fall over so easy
