Author Topic: Academy Models 1:48 Hawker Hunter  (Read 3167 times)
Offline Mikey_W_1980
  • Addict
    • Awards
Re: Academy Models 1:48 Hawker Hunter
« Reply #30 on: Wed Mar, 07, 2018, 04:46:AM »
cheers Bruce....I may get some more bench time tonight :)
All of this has happened before....and will again..
  • Addict
    • Awards
« Reply #31 on: Fri Mar, 16, 2018, 06:07:AM »
Small update...managed to get the basics of the undercarriage assembled. Went together surprisingly well. Basic paint job at the moment.
DSC_1105 by
The decals turned out nicely as well.
[url=https://flic.kr/p/259jHPJ]
DSC_1103 by
Offline Belugawrx
  • Needs Intervention
    • Awards
« Reply #32 on: Fri Mar, 16, 2018, 07:23:PM »
Decals came out GREAT !!
Bruce
  • Addict
    • Awards
« Reply #33 on: Mon Mar, 19, 2018, 06:11:AM »
Cheers @belugawrx they're a bugger to soften and take an age, but the settle down nicely. Managed a some more this weekend, mainly the larger decals then the finer ones once these are dried fully..
DSC_1109
DSC_1108
DSC_1107
The only problem I have to figure out is the markings on the nose section for 54 Squadron, as the decal instructions aren't particularly clear. Further research needed I think?
DSC_1106
More to come....
  • Addict
    • Awards
« Reply #34 on: Mon Apr, 16, 2018, 06:13:AM »
Morning all, a big update, as all the finer detailed decals are now done.......and it took an age to do it too..
DSC_1110
one or two to work through
DSC_1111
DSC_1136
DSC_1135
The level of detail that academy have gone into for this kit is quite impressive.
DSC_1139
DSC_1138
I know the ammo ejection ports are slightly out of position, but they would not sit in the righ place.....
DSC_1141
Next up will be the under carriage assembly and fitting, then some more detailed painting before a clear coat sealant....then done....
Any and all comments are welcomes.
Offline Quaralane
  • Overdose
    • Awards
« Reply #35 on: Tue Apr, 17, 2018, 12:27:AM »
Impressive.
You've put in a lot of markings that I would have likely skipped
  • Addict
    • Awards
« Reply #36 on: Tue Apr, 17, 2018, 05:02:AM »
Though I may as well do the scale justice....plus I'd feel that the kit wouldn't have been represented the way it should be as a Legendary Cold War aircraft of the RAF and a lot of other countries too.
Offline smokeriderdon
  • Addict
    • Awards
« Reply #37 on: Thu Apr, 19, 2018, 10:27:PM »
Very nice!!! The stencils are a pain in the ass, but the are worth it.
  • Addict
    • Awards
« Reply #38 on: Mon Apr, 23, 2018, 04:45:AM »
So this weekend I managed to get the undercarriage, stores and some small details done. this is now about 99% done.....I may do some minor weathering....but not sure as yet...
DSC_1143
A slight issue with one of the front carriage actuators...it snapped in 2 when taking it off the sprue...some some very careful gluing and clentching and it seems to be staying in place.
DSC_1144
DSC_1145
Stores and flaps in place....
DSC_1146
Dried and sitting pretty....just enough weight in the nose to keep it down.
DSC_1147
DSC_1148
The nose gear is a bit flimsy though.....
DSC_1149
DSC_1150
DSC_1154
Thoughts, comments, any pointers on how to improve are all welcomed.
Hope you all enjoy?
Offline Quaralane
  • Overdose
    • Awards
« Reply #39 on: Mon Apr, 23, 2018, 11:47:PM »
Looks good.
