Author Topic: JPG Hailfire  (Read 3590 times)
Offline Dark Kyp
  • Needs Intervention
    • Awards
Re: JPG Hailfire
« Reply #15 on: Tue Nov, 14, 2017, 01:24:PM »
thanks Scott  ;)
Offline peza
  • peza
    • Awards
Re: JPG Hailfire
« Reply #16 on: Thu Nov, 16, 2017, 07:01:AM »
Sweet job Dark lovin ya paint work as always😎
"you there only mean`t to blow the bloody doors off"
Offline Dark Kyp
    • Awards
Re: JPG Hailfire
« Reply #17 on: Tue Dec, 19, 2017, 04:13:PM »
thanks peza!
Next steps:
I improved the rockets with metal tails:
Then painting using the same paint scheme and weathering technics and gluing to the droid's head:
I started the base using foam insulation plate:
I wanted to do a desert stand, so I try to make a dune looks, with the footprints of the droid in it:
Then I used woodpast to create a smooth surface:
Add some paint (flat black and Tamiya desert yellow):
I used some real desert sand. I'm really happy to use it, my sister brought it to me from a trip to Tunisia almost 15 years ago. It comes from tatouine and is so really accurate with star wars theme!  :)
That sand is really thin, I had to go with 3 or 4 layers to achieve that result. That sand also countain little rocks, perfect to add details!  :)
I made little grass using an old brush and add extra details with lichen coming from a forest nearby:
Then I glued the droid to check the positionning of the wheels:
I have to say that the magnet underneath the head really helped me during the gluing of the first wheel.
Offline Dark Kyp
    • Awards
Re: JPG Hailfire
« Reply #18 on: Tue Dec, 19, 2017, 04:13:PM »
Here are the final pictures of my JPG production Hailfire droid!
I add a little micromachine droid on the base to add some realisme to the scene!
I hope you'll enjoy the pictures and feel free to comment!
Offline Quaralane
  • Overdose
    • Awards
Re: JPG Hailfire
« Reply #19 on: Wed Dec, 20, 2017, 12:42:AM »
Turned out really well.
The base is a nice touch
Offline peza
  • peza
    • Awards
Re: JPG Hailfire
« Reply #20 on: Wed Dec, 20, 2017, 12:47:PM »
Roger Roger I agree with Q. Sweet job on this build buddy!👍
Offline blakeh1
  • Addict
    • Awards
Re: JPG Hailfire
« Reply #21 on: Wed Dec, 20, 2017, 01:45:PM »
That turned out great.
A good base really helps as well. I need to put mine on some kind of base
Offline Belugawrx
    • Awards
Re: JPG Hailfire
« Reply #22 on: Wed Dec, 20, 2017, 11:54:PM »
Cool little vignette, ...groundwork came out great
I like the last shot
Bruce
Offline Scott Girvan
  • Scale Model Addict
  • Admin
  • Overdose
    • www.scalemodeladdict.com
    • Awards
Re: JPG Hailfire
« Reply #23 on: Fri Dec, 22, 2017, 01:05:PM »
Great job all around.
Offline Dark Kyp
    • Awards
Re: JPG Hailfire
« Reply #24 on: Thu Dec, 28, 2017, 04:53:AM »
thanks a lot guys!  8)
It has been a nice build!  8)
Someone comes with that advice on another forum:
Quote from: Jason Abbadon
The only thing I might suggest is adding g some sand and grit in the wheel treads so it doesn't look as though it was just dropped there from space (or a modeler!).
So I went back to it and add some dust effects on the wheels and sand on the model here and there.
This way it looks more right in the base. What do you think?
(https://imagizer.imageshack.com/v2/800x600q90/924/1qomQk.jpg)
(https://imagizer.imageshack.com/v2/800x600q90/923/T5t8f2.jpg)
(https://imagizer.imageshack.com/v2/800x600q90/923/5KKvm9.jpg)
(https://imagizer.imageshack.com/v2/800x600q90/922/72r1Cn.jpg)
(https://imagizer.imageshack.com/v2/800x600q90/922/TFIhyf.jpg)
(https://imagizer.imageshack.com/v2/800x600q90/923/L42qQh.jpg)
(https://imagizer.imageshack.com/v2/800x600q90/923/xUa3ZG.jpg)
(https://imagizer.imageshack.com/v2/800x600q90/922/0f2gOX.jpg)
(https://imagizer.imageshack.com/v2/800x600q90/924/EpBeVF.jpg)
(https://imagizer.imageshack.com/v2/800x600q90/924/vU93o8.jpg)
« Last Edit: Fri Dec, 29, 2017, 04:42:PM by Dark Kyp »
Offline Grendels
  • Mod
  • Overdose
    • small business that I own.
    • Awards
Re: JPG Hailfire
« Reply #25 on: Fri Dec, 29, 2017, 03:25:PM »
Well done!
Offline Jason Abbadon
  • Addict
    • Awards
Re: JPG Hailfire
« Reply #26 on: Thu Jan, 11, 2018, 11:16:PM »
Best rendition of the Hailfire I've ever seen!
Better than the CG in the movie!
Offline Dark Kyp
    • Awards
Re: JPG Hailfire
« Reply #27 on: Sun Feb, 11, 2018, 05:27:AM »
thanks guys!  8)
Offline Massassi
  • Habitual User
    • www.massassi.nl
    • Awards
Re: JPG Hailfire
« Reply #28 on: Wed Jul, 04, 2018, 04:21:PM »
Very nice
Offline Dark Kyp
    • Awards
Re: JPG Hailfire
« Reply #29 on: Thu Jul, 05, 2018, 01:39:PM »
thanks  8)
