Author Topic: 40K, Scenery, Battlescape  (Read 1670 times)
Offline The Swedish DR. Plastic
  • Addict
  • Pleas enter, the day has gone to hell any way.
    • Pre TOS, Devian art
    • Awards
« on: Tue Feb, 28, 2017, 06:13:AM »
Hi guys, so here I was planing to show you guys when i paint up my Battlescape scenery using Games Workshop's combination rust colors.   :o   yea right , lol.  ;D
For God's sake Jim I'm a Doctor, not a...
  • Addict
    • Awards
Re: 40K, Scenery, Battlescape
« Reply #1 on: Tue Feb, 28, 2017, 06:18:AM »
So whit no further interruptions, here vegan go :-)
« Last Edit: Tue Feb, 28, 2017, 06:20:AM by The Swedish DR. Plastic »
  • Addict
    • Awards
« Reply #2 on: Tue Feb, 28, 2017, 06:38:AM »
Oh, and comments are welcome.
  • Addict
    • Awards
« Reply #3 on: Tue Feb, 28, 2017, 06:55:AM »
and here is the first part, again. Got complaint on bad audio.
Any way step one I lay down a rust brown base color.
« Last Edit: Tue Feb, 28, 2017, 09:45:PM by The Swedish DR. Plastic »
Offline Scott Girvan
  • Scale Model Addict
  • Admin
  • Overdose
    • www.scalemodeladdict.com
    • Awards
« Reply #4 on: Tue Feb, 28, 2017, 08:57:AM »
I"m not familiar with 40K - so this is a base for gaming? Craters and a tank on it. Looks like a cool piece to paint. You're doing a good job.
  • Addict
    • Awards
« Reply #5 on: Tue Feb, 28, 2017, 04:45:PM »
Yes, its a terrain / scenery set peas. Most people use it as a danger aria due to one side always hide troops in the broken down tank. Me think :-\, I just paint not play.
  • Admin
  • Overdose
    • Awards
« Reply #6 on: Tue Feb, 28, 2017, 06:11:PM »
Cool. Looking good.
Sent from my iPhone using Tapatalk
  • Addict
    • Awards
« Reply #7 on: Tue Feb, 28, 2017, 08:51:PM »
P 2, getting dirty and grimy whit Typhus Corrosion and more rusty whit Ryza Rust
These will be uploaded in a very fast pace ( As I'm writing this I'm editing part 8 ).
« Last Edit: Tue Feb, 28, 2017, 08:53:PM by The Swedish DR. Plastic »
  • Addict
    • Awards
« Reply #8 on: Tue Feb, 28, 2017, 08:58:PM »
P 3, Still working whit Ryza Rust to cover all the pieces.
  • Addict
    • Awards
« Reply #9 on: Tue Feb, 28, 2017, 09:00:PM »
P 4, Now Its time to hide the exes Ryza Rust by adding another layer of Typhus Corrosion.
  • Addict
    • Awards
« Reply #10 on: Tue Feb, 28, 2017, 09:02:PM »
P 5, At this point I was planning to stop, as i was just going to show how i used the two combination paints, but decided to record the hole thing. So as I start back up again I skipped recording wen i painted the dirt color. And as I start up this recording I'm working whit GW Texture Color Astrogranite.
The second color I Use is one I mixed my self, its basically a darker shade of WW II German Gray (helmets)
Next step was to add some extra crater texture, that I then added a layer of Astrogranite to.
« Last Edit: Fri Mar, 03, 2017, 05:16:AM by The Swedish DR. Plastic »
  • Addict
    • Awards
« Reply #11 on: Tue Feb, 28, 2017, 09:18:PM »
P 6, As I continued I decided I wanted the Texture paint on all exposed bed rock, and painted them up.
Made a wet pallet (Tabletop Minions) and started experimenting whit ground colors.
  • Addict
    • Awards
« Reply #12 on: Wed Mar, 01, 2017, 01:46:AM »
Ok here are the remaining 7
P 7, At this time in the construction i decided to try another shade of dirt color.
later I started some dry brushing on the exposed bed rock.
P 8, I continue  the dry brushing of the bed rock.
After witch i went online and did some research on alternate earth color, after a light coat of GW Mechanicus Standard Grey on the old earth color. I went whit a layer of GW Mournfang Brown, whit a dry brush layer of GW Steel Legion Drab.
P 9, Ok so a second layer of GW Mournfang Brown before starting dry brushing whit Steel Legion Drab.
P 10, At this Point I decided to go whit GW Eshin Grey on all exposed Bed rock,  and as I start up the recording I'm in the procese of dry brushing it whit GW Administratum Gray.
After witch I move on to the burnt treas, whit the same  GW Administratum Gray.
A skipped recording, and you can see I have added some tufts of grass and are in the process of adding some wash to the many skulls.
P 11, Some last touch ups on the skulls, and I move on to base paint the skeleton.
Then i started dry brushing the bases of the treas, and the rest of the treas as well.
P 12, I continued whit the different types of armor and weapons (one broke of). As well as giving the skeleton some bloody bones (of camera).
P 13, Final stretch now, gave the danger sign the rust treatment.
And painted up the final two treas.
And the end result.
« Last Edit: Fri Mar, 03, 2017, 05:39:AM by The Swedish DR. Plastic »
  • Admin
  • Overdose
    • Awards
« Reply #13 on: Thu Mar, 02, 2017, 09:25:PM »
Cool. Ill catch up on some of these
