Author Topic: MPC Hoth Rebel Base model set  (Read 2084 times)
Offline stevethefish
  • Habitual User
    • My homepage
    • Awards
Re: MPC Hoth Rebel Base model set
« Reply #30 on: Tue May, 30, 2017, 10:22:PM »
So... maybe measure the width of one of the S-foils for the tiny MPC X-Wing, measure that of the Fine Molds's X-Wing, calculate a ratio, then resize the decal sheet accordingly? The proportions more or less match, so this may be hurdling the wall I've come up against.
Offline Quaralane
  • Overdose
    • Awards
« Reply #31 on: Tue May, 30, 2017, 11:41:PM »
Basically, yes
Offline Scott Girvan
  • Scale Model Addict
  • Admin
  • Overdose
    • www.scalemodeladdict.com
    • Awards
« Reply #32 on: Wed May, 31, 2017, 10:15:AM »
Yup, that would do it. I'd test print on paper first though.
  • Habitual User
    • My homepage
    • Awards
« Reply #33 on: Wed May, 31, 2017, 10:49:PM »
Yes, I'd definitely do a test print first. I have some other stuff I wanna print out on decal paper, so I will try to maximize what I've got. I'll take it to work and use the laser printer there.  ;)
I haven't done a video on this project in a while. The only work I've done is re-wiring the blue LEDs into the Transport ship. This time I used clear epoxy glue instead of hot glue so that they won't shift around when it gets warm.
  • Habitual User
    • My homepage
    • Awards
« Reply #34 on: Thu Oct, 05, 2017, 08:57:PM »
When assembling the Rebel Transport, I encountered the same problem I had with the last one: the gluing contact point on the rear starboard side along the side-trench does NOT want to cooperate. This stubborn part did not want to meld together. I used a rubber band around the transport to fix this. My friend said he had the same issue when he built his, so apparently it's a problem with the way the kit is made.
But now that this is done, I intend to start painting it soon.
That same friend has constructed some decent side docking ports for this kit's Falcon. I'll need to use my router to cut the existing spots open and install those once I get them.
  • Habitual User
    • My homepage
    • Awards
« Reply #35 on: Mon Oct, 23, 2017, 08:40:PM »
An update at last! Here I have airbrushed the Rebel Transport with lots of paneled stripes. After recording this video, I sprayed it with future to prepare it for artist oil washes. I used Tamiya acrylics on this. First I used Neutral Gray, then, Dark Sea Gray, and finally Sky Gray.
Offline blakeh1
  • Addict
    • Awards
« Reply #36 on: Tue Oct, 24, 2017, 06:04:PM »
Looking good. it should weather up nicely
Offline Jason Abbadon
  • Addict
    • Awards
« Reply #37 on: Wed Oct, 25, 2017, 03:58:AM »
Looks really good! Maybe keep your weathering to warmer tones like burnt umber and cienna mixed with grey or black- the basecoat are very cool in tone and could use some warming up.
  • Admin
  • Overdose
    • Awards
« Reply #38 on: Thu Oct, 26, 2017, 09:26:AM »
Decals look great, should work out real nice on this tiny Xs. Transport is going to be cool too. You make me want to dig this old build outta a box and revisit it.
Offline Grendels
  • Mod
  • Overdose
    • small business that I own.
    • Awards
« Reply #39 on: Mon Oct, 30, 2017, 01:16:AM »
This is going to look fantastic at the end.
  • Addict
    • Awards
« Reply #40 on: Wed Nov, 01, 2017, 02:27:PM »
Maybe go back and must the top of the transport with white to simulate snow and frost in areas? Hoth was bitterly cold and there should be at least frost on darn near everything.
  • Habitual User
    • My homepage
    • Awards
« Reply #41 on: Wed Nov, 01, 2017, 07:03:PM »
Actually, I am not going for an "escape from Hoth" since I'll have the Falcon flying with it. For one thing, this Transport isn't accurate to the filming prop much at all. The cockpit module is all wrong, etc. So, this diorama I'm building could be more of an "escape from Yavin IV" instead. The transport looks different, so I'm not going to bother trying to make it look like the ones seen in ESB.
As for the striping painting scheme, I was rather inspired by the Hasbro Star Wars Titanium Series Rebel Transport I have on my desk. I'll show that in the next video. That miniature features blue and beige panels, so mine is a bit more subdued. Here is a picture: http://img.militaria-girona.cat/5733-thickbox_default/rebel-transport-dark-grey-micromachines-titanium-spaceships-diecast.jpg
