Author Topic: Space Battleship Yamato stuff  (Read 6529 times)
Online blakeh1
  • Addict
    • Awards
Re: Space Battleship Yamato stuff
« Reply #30 on: Mon Apr, 17, 2017, 02:32:PM »
base plastic colors ;D
I tried an experiment. I was going to mix up some vallejo for the colors, but when looking at how I was going to mask it off, I started to realize it would be a nightmare unless I took it apart.
Also, this thing is pretty small and I was worried about losing detail after priming and then base coating.
It goes against my bare plastic avoidance OCD, but I decided to try "faking" a base coat by just using some GW Matte Varnish to dull down the plastic shine and give a little bit of surface to grip.
Then I mixed up some black, green, brown oil washes/stains/rubs.
Then I used some white toned down with just a touch of black to dry brush it. I then further blended that to make it look smoother
You can see the difference between the bare plastic and the "weathered, shaded and highlighted" plastic by looking at the grey square block at the top of the stand
It's a fairly convincing effect, but I can't help wonder if it would have looked better with a painted base coat. Maybe someday I will bit the bullet and try painting it
Online urumomo
  • Overdose
    • Awards
« Reply #31 on: Mon Apr, 17, 2017, 02:42:PM »
  Color's color .
  Doesn't matter what material it's coming from .   paints are plastics - resins - anyways
  I don't know exactly what the torpedo tubes are supposed to look like ,  but you can get cool effects with inks in Future .
  --  metallic inks and also dyes  ,
  I found that a lot of the acid dyes -  powders - used for textiles produce some really unexpected effects  ,,, with all kinds of bonuses depending on the underlying color
Offline Jason Abbadon
  • Addict
    • Awards
« Reply #32 on: Sun Apr, 23, 2017, 05:10:PM »
Still haven't gotten around to doing the extra markings on the "dreadnaught" (at least that's what it is being called in the new 2202 releases)
I may use the new on as a guide for some extra markings
At any rate. Something newer kit wise, the Dimensional Submarine UX-01. One of my favorite ships from the 2199 series
I tried using white oil paints drybrushed and then blended a little further after doing darker washes to create some highlighting. I still haven't figure out how I want to handle the "glow effect" around the "torpedo tubes"(?)
Looks great! The glowy bits can.be achieved with florescent green paint- gradient to white towards the center for a "glow".
« Last Edit: Tue Apr, 25, 2017, 10:37:PM by Jason Abbadon »
Offline Scott Girvan
  • Scale Model Addict
  • Admin
  • Overdose
    • www.scalemodeladdict.com
    • Awards
« Reply #33 on: Sun Apr, 23, 2017, 05:14:PM »
Always liked these ships. Man, beauty work on these.
Sent from my iPhone using Tapatalk
Offline Quaralane
  • Overdose
    • Awards
« Reply #34 on: Sun Apr, 23, 2017, 11:10:PM »
Not terribly practical designs, but they definitely look cool
Offline Grendels
  • Mod
  • Overdose
    • small business that I own.
    • Awards
« Reply #35 on: Mon Apr, 24, 2017, 01:11:AM »
I too love the designs....
Online blakeh1
  • Addict
    • Awards
« Reply #36 on: Thu Sep, 07, 2017, 09:04:PM »
Indeed!
Almost finished the 1/1000 2199 Cosmo Reverse version (left off the wave motion gun plug though)
Again I decided the plastic color was actually quite good and actually would save a lot of time using it instead of painting.
So i used the similar process I used on the sub
I matte coated it. Added some black/brown staining, let it dry. Then drybrushed some white oil spots and wiped them vertically.
the effect in the pics doesn't show up as much on the red hull bottom as it got washed out
Hopefully it doesn't look like plastic anymore
The tiny ships were a pain to try making them look like something other than colored blobs
« Last Edit: Thu Sep, 07, 2017, 09:06:PM by blakeh1 »
Offline Quaralane
  • Overdose
    • Awards
« Reply #37 on: Fri Sep, 08, 2017, 12:09:AM »
Looking really good there
Online blakeh1
  • Addict
    • Awards
« Reply #38 on: Sun Nov, 26, 2017, 01:36:PM »
thanks for looking!
Got the Garmillas ship from set 4 done
the growing fleet
Got the Andromeda painted up. ready for some subtle weathering and decals
  • Addict
    • Awards
« Reply #39 on: Thu Nov, 30, 2017, 02:28:AM »
VERY nice! Andromeda looks amazing!
Offline stevethefish
  • Habitual User
    • My homepage
    • Awards
« Reply #40 on: Fri Dec, 01, 2017, 01:51:AM »
You're very good at painting fine details. Excellent work!
Online blakeh1
  • Addict
    • Awards
« Reply #41 on: Mon Dec, 04, 2017, 08:29:PM »
thanks guys
speaking of fine details, I painted two of the little fighters for it.
Many areas are smaller than my brush size and I am using a tiny brush.
They look fine from normal viewing distance, but kind of look a little messy zoomed in though. Not just painting-wise, but proportion wise. The Tiger IIs seem to be a little better than the Falcon and the Zero. The Zero especially has way out of scale proportions in areas and lots of things look too "fat" when zoomed in
At any rate, I somehow thought that the Cosmo Tiger II would have been a little larger compared to the Falcon and Zero, but apparently not
Offline Hagoth
  • Addict
    • The Brass Ball
    • Awards
« Reply #42 on: Wed Dec, 06, 2017, 09:13:PM »
Even with "Fat" details at such a small scale these still look amazing to me.  They are easily recognizable for what they are intended to represent.  Nicely done!
_________________
"It's kind of fun to do the impossible." - Walt Disney
Offline Quaralane
  • Overdose
    • Awards
« Reply #43 on: Fri Dec, 08, 2017, 12:12:AM »
I second that, Hagoth
Offline Vknight401
  • Habitual User
    • PCLetsPlay.com
    • Awards
« Reply #44 on: Fri Dec, 08, 2017, 08:45:AM »
i love the yamato series and the kits, i have the andromeda coming to the store today, i'm debating selling it or giving myself an early xmas gift  ;D
PCLetsPlay.com
